KINGS QUEST 5
First post, by photon6786
This is my last forum post, this will kinda help explain the senerio. I have all the files in a folder. I just drag the SIERRA applicatino file onto DOSBOX, and the game loads fine. But when I go to try to save a game, it says there is not enough room. The folder contains everything on the CD itself. Every time I try to run the setup though, it says "Youor current display driver is not supported by this game. You can install a different driver by selevting the appropriate options from the control panel" I would really like to play this game and be able to save game files also. Is there any way maybe I could just somehow have it where I can just "play it off the cd" (which is actually on a folder on my pc) and be able to save in that folder somehow? Thanks.
Reply 1 of 3, by photon6786
Well, it helps if I actually post the link of my last forum post =P:
Save Games Problem
Reply 2 of 3, by collector
Run the DOS install.exe, not the Windows setup.exe and play the game in DOSBox.
Reply 3 of 3, by photon6786
I tried, says i need to insert disk 1, I even copied the files that were in the "1" folder onto a floppy, still didnt work
