Reply 20 of 22, by matze79
It will not suffice load a tsr in dosmode before chainloading NT, NT will overwrite the memory and the tsr will not work within NT.
You need extra Code for NT.
You can try to chainload NT with Grub4DOS so you can load NT Bootcode from MS-DOS.
i once did this on a T600 to enable Cache on Pentium 3 CPU..
