First post, by yourepicfailure
I've been reading through these boards and others, and well I think I might as well share to help benefit the T3100SX community.
Some folks out there have been wanting a few pics of the proprietary ram card. Well, the fact is, there is not one single design. I have four different versions of the ram card with each also using different sets of dram chips.
Hopefully these can be of use. I couldn't get a perfect focus no matter how hard I tried, so I apologize for the blurriness. But they should be detailed enough to get something out them.
https://mega.nz/#F!GKAQDaLC!UcvC70HvJetX2ZwYeGWfHg
As you can see, each version is of different quality and design depending on the manufacturer. However, Type II reveals the ram modules all use a KEL 8900 series connector. These connectors are actually still manufactured:
https://www.kel.jp/english/product/product_de … d=376&p_cont=39
The catalog PDF has the most detail.
They appear to be 2 layer boards and each of the modules vary in size. I would not, however, stray more than 65mmx41mm.
If you need additional details, please ask.
My fourth board is a stand-by in the event one of the other modules fail. If someone wants to borrow it for further study, that can be arranged.
