First post, by aazard
- Member
Hi i just bought a Zotac Nvidia Geforce GT 520 PCI 1024mb from a local thrift shop, tested to work in a amd socket A system. would this work in a Biostar MB-8433uud socket 3 motherboard?
If anyone has tested this before or has both components, i'd like to combine with with my soundblaster awe with 28mb added ram, a tested working combo gigabit/2-port usb2.0 pci card and even 256mb edo ram (4 x 64mb simm's).
I can get a 83mhz pentium overdrive running at 40mhz x 2.5 (100mhz) for the CMPXCHG8B instruction/feature (i plan to disassemble do 4v mod, add "liquid metal" paste for cooling, as i have some, and replace cooler/fan with custom ones..i dont want it dying @ 100mhz)
i have the "UUD2014" modified bios files and am able to complete all mods to cpu/mobo for 4v cpu power, getting a full 1024KB of L2 cache and even pinning up the mighty ps/2 mouse port. I have a 80-pin ide cable and ide to sata converter to use with a unopened 2.5 inch sata 128GB samsung ssd.
My plan is to install windows 7?? on it, seeing as i can not use the sse required 2018 patches, nlite out the cpu speed/memory check and other stuff and CMPXCHG8B should be all i need.
i should get:
- a 100mhz P54C type cpu, very well cooled
- 256mb edo ram fully write thru cached
- atleast 1x 128gb ssd
- a gigabit ethernet plus 4x usb 2.0 (2x int/2x ext) port combo pci card
- a 1gb GT520 gpu, (failing that i'm fairly sure a pci 256mb fx5500 will work if i have done my homework on forum)
- (isa soundblaster awe32 with 28mb added ram but only for dos/win98se), an external usb sound "card" for running in windows 7.
- if i get an Adaptec 29160 ultra160 card i can have 4+ ssds @ theoretical 160mb/sec
- space for an non-vlb 4mb isa mach32/mach64 or isa et4000/et6000 (if the main gpu fails to work/work well for dos)
(but pci 2.0 bus is limited to 133mb/sec i think, but board might be pci rev 2.1)
is this possible??
EDIT: seems i cant use ISA cards in windows 7 (if i read correctly), but vista would support them...but no vista....SO
i will swap the awe32 isa card for a USB "external sound card" in windows 7, i should be able to leave isa awe32 card in place for windows 98se/msdos 7.10... seeing that i may get away with a "secondary" isa video card like a et4000/et6000 or mach32 for dos games if my main gpu sucks/isnt supported in dos
It is also suggested many places i get "ultra 160", for a theoretical 160mb/sec (i would think more hitting around ata133 speeds), or atleast a "ultra2" about 80mb/sec pci SCSI card with sata to ultra lvd160 (or ultra2) adapter (adaptec seems to have modles supporting dos to windows 7 & linux, like the Adaptec 29160 ultra160 card)
I have an 4 old "project gena" winpe1 discs, 2 made win xp, 2 made with win 2003..each has a load all to ram version & a load from cd version... i wonder if they would run on this
Aazard -
Mono Planar Mortal & Unascended Master
Retro Enthusiast & L3 Trouble Shooter
.... Getting old
