Reply 20 of 139, by Dominus
- DOSBox Moderator
I have to try again, there was something else going wrong after I had exchanged these with decimals...
ok, had another go.
First I found that my "illegal instruction" crash I experienced last time was due to adding the wrong decimal value to one of the binaries.
But I'm not much further now 🙁
When I switch to dynamic core it just freezes. Eventually I just have to force kill it.
A non-debug build gives this information via gdb:
#0 0x0021f024 in PIC_RunQueue ()#1 0x0000eb98 in _ZL11Normal_Loopv ()#2 0x000070dc in DOSBOX_RunMachine ()#3 0x00015154 in CALLBACK_RunRealInt ()#4 0x004a7b10 in DOS_Shell::Execute ()#5 0x004a25f4 in DOS_Shell::DoCommand ()#6 0x004a21f8 in DOS_Shell::CheckConfig ()#7 0x004a2614 in DOS_Shell::DoCommand ()#8 0x00494aa0 in DOS_Shell::ParseLine ()#9 0x00495150 in DOS_Shell::Run ()#10 0x00497220 in SHELL_Init ()#11 0x0048457c in Config::StartUp ()#12 0x00275724 in SDL_main ()#13 0x004c6658 in -[SDLMain applicationDidFinishLaunching:] ()#14 0x92bf5e1c in _nsnote_callback ()#15 0x90805ec0 in __CFXNotificationPost ()#16 0x907fdf20 in _CFXNotificationPostNotification ()#17 0x92be0224 in -[NSNotificationCenter postNotificationName:object:userInfo:] ()#18 0x937a3be8 in -[NSApplication _postDidFinishNotification] ()#19 0x937a3ad4 in -[NSApplication _sendFinishLaunchingNotification] ()#20 0x937a361c in -[NSApplication(NSAppleEventHandling) _handleAEOpen:] ()#21 0x937a31c4 in -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] ()#22 0x92bf6e28 in -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] ()#23 0x92bf6c88 in _NSAppleEventManagerGenericHandler ()#24 0x91500960 in aeDispatchAppleEvent ()#25 0x915007fc in dispatchEventAndSendReply ()#26 0x91500654 in aeProcessAppleEvent ()#27 0x932bf2e0 in AEProcessAppleEvent ()#28 0x937a190c in _DPSNextEvent ()#29 0x937a13f8 in -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] ()
I have no debug build at hand because I don't have curses built. Another task for another day.
jmarsh, anything else you want me to do? add some printouts?
Things I changed so far in the code to make it compile:
- binaries to decimal in risc_ppc.h
- commented "#define USE_SDA_BASE" in risc_ppc.h (as per your instructions)
- changed config.h after ./configure with #define C_DYNREC 1
Good news from PowerMac G4 land; both the dynrec and drive sector-size patches are working well. The dynamic core lets DOSBox operate at roughly 4600 cycles before this machine's CPU maxes out and starts dropping audio chunks, where as the normal core only allows up to 2400 cycles.
Very nice work on this patch jmarsh!
This is on a PowerPC-7400 400Mhz machine running an up-to-date Ubuntu Linux. It was a pleasure to see DOS games running at fast 386 speeds, given this machine came out in 1999 when Microsoft still supported DOS 7.0! 🤣
Some notable system-configurations needed to get a usable and accelerated X display:
And the usual gang of linux details..
kernel (uname -a)
Linux pillow 4.4.0-164-powerpc-smp #192-Ubuntu SMP Fri Sep 13 12:02:52 UTC 2019 ppc ppc ppc GNU/Linux
cat /proc/cpuinfo
processor : 0cpu : 7400, altivec supportedtemperature : 27-29 C (uncalibrated)clock : 400.000000MHzrevision : 2.9 (pvr 000c 0209)bogomips : 49.81timebase : 24908750platform : PowerMacmachine : PowerMac3,1motherboard : PowerMac3,1 MacRISC Power Macintoshdetected as : 65 (PowerMac G4 AGP Graphics)pmac flags : 00000004L2 cache : 1024K unifiedpmac-generation : NewWorldMemory : 1280 MB
lspci
0000:10:0b.0 Host bridge: Apple Inc. UniNorth PCI0000:10:0d.0 PCI bridge: Digital Equipment Corporation DECchip 21154 (rev 05)0000:11:07.0 Unassigned class [ff00]: Apple Inc. KeyLargo Mac I/O (rev 02)0000:11:08.0 USB controller: Apple Inc. KeyLargo USB0000:11:09.0 USB controller: Apple Inc. KeyLargo USB0000:11:0a.0 FireWire (IEEE 1394): Texas Instruments TSB12LV23 IEEE-1394 Controller0001:21:0b.0 Host bridge: Apple Inc. UniNorth Internal PCI0001:21:0f.0 Ethernet controller: Apple Inc. UniNorth GMAC (Sun GEM) (rev 01)5f08:00:0b.0 Host bridge: Apple Inc. UniNorth AGP5f08:00:10.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Rage 4 [Rage 128 PRO AGP 4X TMDS]
cat /proc/asound/cards
0 [Screamer ]: PMac Screamer - PowerMac ScreamerPowerMac Screamer Rev 0
(44,100 Hz native sampling rate with 1024 blocks)
lsb_release -drc
Description: Ubuntu 16.04.6 LTSRelease: 16.04Codename: xenial
xorg.conf settings needed to get an accelerated XV overlay with a reasonable VGA window-size (1440x1040)
Section "Module"Load "dri"Disable "dri2"Load "extmod"Load "freetype"Disable "glx"Disable "dbe"Load "i2c"Load "bitmap"Load "ddc"Disable "int10"Load "type1"Load "vbe"EndSectionSection "Monitor"Identifier "Monitor0"VendorName "Monitor Vendor"ModelName "Monitor Model"HorizSync 28-70VertRefresh 43-60EndSectionSection "Device"Option "DMAForXv" "True"Option "VGAAccess" "True"Option "RenderAccel" "True"Option "AGPMode" "4"Option "Accel" "True"Option "EnablePageFlip""True"Option "UseFBDev" "False"Identifier "Card0"Driver "r128"EndSectionSection "DRI"Mode 0066EndSectionSection "ServerFlags"Option "AIGLX" "False"EndSectionSection "Screen"Identifier "Screen0"Device "Card0"Monitor "Monitor0"DefaultDepth 16SubSection "Display"Depth 16EndSubSectionEndSection
gcc -v
Using built-in specs.COLLECT_GCC=gccCOLLECT_LTO_WRAPPER=/usr/lib/gcc/powerpc-linux-gnu/5/lto-wrapperTarget: powerpc-linux-gnuConfigured with: ../src/configure -v --with-pkgversion='Ubuntu 5.4.0-6ubuntu1~16.04.11' --with-bugurl=file:///usr/share/doc/gcc-5/README.Bugs --enable-languages=c,ada,c++,java,go,d,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-5 --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-libitm --disable-libquadmath --enable-plugin --with-system-zlib --disable-browser-plugin --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-5-powerpc/jre --enable-java-home --with-jvm-root-dir=/usr/lib/jvm/java-1.5.0-gcj-5-powerpc --with-jvm-jar-dir=/usr/lib/jvm-exports/java-1.5.0-gcj-5-powerpc --with-arch-directory=ppc --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --enable-objc-gc --enable-secureplt --disable-softfloat --with-cpu=default32 --disable-softfloat --enable-targets=powerpc-linux,powerpc64-linux --enable-multiarch --disable-werror --with-long-double-128 --enable-multilib --enable-checking=release --build=powerpc-linux-gnu --host=powerpc-linux-gnu --target=powerpc-linux-gnuThread model: posixgcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.11)
CFLAGS, CXXFLAGS:
-mcpu=7400 -Ofast -ffast-math -maltivec -mabi=altivec -fstrict-aliasing -mpowerpc-gfxopt -fomit-frame-pointer -pipe
Were you able to build with "#define USE_SDA_BASE" left uncommented (active) in risc_ppc.h?
wrote:Were you able to build with "#define USE_SDA_BASE" left uncommented (active) in risc_ppc.h?
Yes, the only change I made was defining C_DYNREC 1 in config.h after ./configuring.
Left everything else as-is. Here's a copy and from risk_ppc.h:
// disable if your toolchain doesn't provide a _SDA_BASE_ symbol (r13 constant value)#define USE_SDA_BASE
So it turns out OSX uses a different ABI for PowerPC which won't work with this code, I'll have to make some adjustments.
Isn’t this dead since 10.5?
Patch in first post updated, should hopefully work with OSX now.
Edit: And again, because apple's gcc confuses comments and instructions.
Confirming no regressions on the Linux side; updated patch still builds and runs just as before.
I need this patch for 10.3.9 PPC G4, but have no experiences on how to compile dosbox binary, but I have installed the development-tools.
Is there a simple howto for a newbee ?
Thx
Doc
@dominus
Kann Dir einen PPC G4-Mini mit 10.3.9 und allen tools installieren und zusenden.
https://www.dropbox.com/s/kvhujmw1crygmow/dos … vn.app.zip?dl=0 <- that's my build. Run it with output opengl. Remember to use the correct preference file. It might fail on a 10.3 system though. Some stuff needs 10.4 I think. Never tried below 10.4
Ich würde lieber nicht mit einem fremden Gerät rumhantieren und gerade bin ich ehrlich gesagt zu kaputt um eine Anleitung hervor zu zaubern. Aber 10.3 kann echt eine Hürde sein. Now back to English, please 😀
No problem for me, take that machine as a gift. A have several ones 😉
All I need is your adress and I will sent a ready to go package.
I don't think that I can do that by myself.
First I will test your app on my setup.
I have tested your build from 14.10.19 and as you said, it does not work on 10.3.9.
wrote:https://www.dropbox.com/s/kvhujmw1crygmow/dos … vn.app.zip?dl=0 <- that's my build. Run it with output opengl. Remember to use the correct preference file. It might fail on a 10.3 system though. Some stuff needs 10.4 I think. Never tried below 10.4
Is this build still available? This link 404s.
Failing that, I can reconstruct it on my G5, but I'm not sure which revision it was done against (though I guess the patch should still work against tip?).
I think it should still apply cleanly, if not it's no trouble for me to update it.
Okay, I've reconstructed it against trunk. Nice work! I built it with gcc 4.0.1, the default with Xcode 2.5. It didn't like one of the inline asm blocks and using sys_icache_invalidate() in the commpage is probably better anyway (less likely to have side effects), so I tweaked risc_ppc.h with some __APPLE__ ifdefs. Otherwise it "just worked" without changes. Death Rally is now playable on the G5 without having to run the cores in Maximum Space Heater mode.
I think I'll see about porting this to ppc64le next. Much of it should work, though the ABI is a bit different.
What exactly was the problem with the inline asm?
It didn't like the register constraint. I wouldn't sweat it that much because it's an old compiler, and sys_icache_invalidate() is better on OS X anyway.
