Identify the card in this picture?
Reply 20 of 26, by cyclone3d
More pics:
Motherboard has 32KB of L2 cache currently installed. Also has places for turbo LED and turbo switch but they are unpopulated. The case doesn't have a plase for them. I may add the switch and LED posts and test it out.
Hopefully the manual will have jumper settings for the cache settings so I can install more.
The attachment motherboard.jpg is no longer available
overhead view
The attachment insides.jpg is no longer available
One of the socketed chips near the L2 cache has a mangled leg. Really doubt it is even making contact. Looks like it came that way from the factory.
The attachment chip_bent_leg_1.jpg is no longer available
The attachment chip_bent_leg_2.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21 of 26, by cyclone3d
And the extent of the damage caused by the leaking battery.
Looks like even the ground traces are fine. Just discolored.
The attachment battery_top.jpg is no longer available
The attachment battery_bottom.jpg is no longer available
YMF7x4 Guide
Reply 22 of 26, by keropi
Nice system!
About the SCC-1, the newer version is silkscreened SCC-1A
It really is no issue in gaming, maybe if you compose music you would want the extra samples but otherwise they go unused AFAIK
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 23 of 26, by yawetaG
That bottom slot...if you were to solder another ISA slot to the unused area right behind that slot (below the memory), would that be one of those manufacturer-specific 32 bit slots?
Reply 24 of 26, by dionb
Looks more like a memory card slot to me, but not too up-to-speed on mid-period 386, so could be wrong.
Reply 25 of 26, by cyclone3d
Yeah, I think it is probably for some sort of memory card as well. I did find a few similar boards on statson.org that list it as a 32-bit memory add-on card slot.
YMF7x4 Guide
Reply 26 of 26, by Thermalwrong
The PC is nearly as nice as the Roland card that was in it 😀 That's great that the corrosion is pretty minimal - but what's up with those capacitors coming off the keyboard connector and going to ground?
