First post, by Akril15
Hello,
I’ve purchased a copy of Windows 3.11, intent on installing and running it in DOSbox, but after reading over the only Windows 3.x guide I could find here, I’m beginning to feel much more uncertain about this endeavor than I was previously.
For instance, the guide says that all you have to do to install Windows 3.x in DOSbox is to adjust some of the dosbox.conf settings, copy the installation files to C:\doswin\win31 and then enter this in DOSbox:
mount c c:\doswin
cd c:\win31
setup.exe
Yet earlier in the guide (and in later posts), the author warns the reader not to mount the C drive as C in DOSbox, since it could mess up the settings of your main OS. Forgive me if I sound simple, but I don’t really understand what I should do instead of mounting C:\. At first, I assumed that I should use a mounted image (something I’m not familiar with; I tried making a CD image once, but I was quite unsuccessful), but the author only mentions a mounted image as an alternative to the method he mentioned.
Could somebody please clarify what I should do to successfully install Windows 3.11 via DOSbox? I’ve done everything else that the Win 3.x guide mentions, but I’m just puzzled about the final instructions.
(By the way, by OS is Windows XP, and I’m using the DOSbox 0.63 CVS. I don’t think any other system info is needed yet.)
