Reply 200 of 930, by FreddyV
matze79 wrote:
Mod Master conflicts with Tandy Card at 0C0h on 386.
If i set the Card to 1E0h it works just fine.
You mean your tandy card ?
There is probably something wrong with it, as no I/O are supposed to be done at these @
I added a code to detect the Tandy DAC, but it is doing only read/Write to a registry, I use a standard detection code.
And the R/W are not done if no Tandy BIOS is present.... Really strange.
Here is the code:
PROCEDURE TDY_DetectDAC; Assembler;
Asm
MOV AX,8100h
INT 1Ah
CMP AX,00C4h {Detect the Tandy DAC BIOS }
JNE @DACDETECT_NODAC
MOV DX,TDY_Port_FreqL
IN AL,DX
MOV CL,AL { Save de Port Value }
XOR AX,AX { Write 0 to the Port }
OUT DX,AL
IN AL,DX
OR AL,AL { Read and Compare }
JNZ @DACDETECT_NOPort
NOT AX { Write 0FFh to the Port }
OUT DX,AX
IN AX,DX
NOT AX
MOV AL,CL { Restore the Value }
OUT DX,AL
MOV TDY_Type,2 { Found -> 2 }
JMP @DACDETECT_End
@DACDETECT_NOPort:
OUT DX,AL
MOV TDY_Type,1 { Only IRQ Found : 1}
JMP @DACDETECT_End
@DACDETECT_NODAC:
MOV TDY_Type,0 { Not Found -> 0 }
@DACDETECT_End:
End;
Do you mean that due to this, it mess up the sound with other sound devices ?
Reply 201 of 930, by FreddyV
matze79 wrote:
This happens with SB, Covox and Speaker, i have no idea why, is there a Debug Mode ?
GLX Player just works fine here.
On my NEC V20 it works 😀
Are you sure that the mixing frequency is not too High ?
Reply 202 of 930, by matze79
Ah its nothing Strange.
I use SB16, and its using the Second DMA Controller.
But Tandy Card at 0c0h is conflicting with DMA Controller #2 on AT Systems.
A XT does not have a Second DMA Controller, and therefore no conflict.
If i remove SB16, problem is gone.
I was not thinking about this because i used Covox.. and it also conflicts with the SB Card when i`m not use it for playback.
Reply 203 of 930, by keropi
FreddyV wrote:
Yes it is, you have the Playlist buttons just on the right (Load/Save and so on) […]
keropi wrote:
^ allright!
but does it support to load a saved playlist? need to mess with it more I think... I am using cubic player atm...
Clubic player is better than MOD Master on a 486, and I have a "Better" Version of Mod Master in VGA.
Anyway, if you like it, it is not a problem for me 😀
The VGA Version of Mod MAster is untouched since 1997, it has some replay bug that Mod Master XT does not have anymore.
(If you search in this thread, I think I did publish Mod Master 2.3)
I don't really care about VGA gfx or other duddah - text mode and playlists are awesome for me... I really must play with the software more - all I did until now is a 10min test of Uncle Tom's Poseidon mod 🤣
I can't believe I missed this so far 😐
Reply 204 of 930, by zyga64
I have different version of GSLINGER.MOD with the same size. Sounds the same for me, but didn't crash 😀
It may be usefull to compare both versions.
The attachment GUITAR.zip is no longer available
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 205 of 930, by FreddyV
GUITAR.zip
Thanks, I already found and corrected this problem it will be in the next release.
Reply 206 of 930, by matze79
Can you add a Option to prevent Auto Detection of Devices ? /noauto
Reply 207 of 930, by FreddyV
I checked the full code and I see no Read/Write to the 2nd DMA.
Strange…
FreddyV
Reply 208 of 930, by MobyGamer
FreddyV wrote:
Teaser for the next release:
https://www.youtube.com/watch?v=4UwfN0hf79k
Dedicated to MobyGamer 😀
You are insane!
So, I finally had time to test v10 from several weeks ago, and all of my issues are fixed. No more arpeggio issues, no other issues. Even PC Speaker worked @ 11KHz on an 8MHz 8086. This is a remarkable achievement!
Reply 209 of 930, by xjas
^^ @FreddyV: are you emulating the PC speaker through the GUS to play those? Pretty cool.
Reply 210 of 930, by FreddyV
MobyGamer wrote:
You are insane!
Thanks 😀
There is root42 reporting Bugs so my debug sessions are not finished.
I Will need you because I integrated monotone code and it is taking too much memory. I Will send you my monotone modified code so that you can check.
One of my new goal is to integrate adlib tandy pc speaker music to be able to do a full demonstration of what can be done with an xt.
I Will do 2 two separated executables one for mod and s3m and another with all.
I currently fight to have adlib SAT music working again...
My holidays are comming so code slow down during one month
Reply 211 of 930, by FreddyV
Hi.
To play Monotone files ?
I use direct the monotone tracker code
Edit : I understood. It show Gravis for Mod Master code, But monotone code is separated.
Tandy emulation can be there if trixter is motivated To do it... 😀
Reply 212 of 930, by MobyGamer
There will never be a monotone file over 64K, so is this really a problem? IIRC the monotone code is just treated as one big array...
That was one goal of MONOTONE v2.0 but I never got around to writing it. The hardest part is finding a tracker that can support FM + tandy + speaker (+ SB digi for digidrums). There is no tracker that can create that kind of thing yet.
Reply 213 of 930, by root42
Doesn’t the Planet X3 tracker support either Adlib, Tandy or PC speaker? Or do you mean all at once...?
YouTube and Bonus
Reply 214 of 930, by MobyGamer
It does, but 1. it's not released to the public, and 2. I did mean all at once.
It is possible for a 4.77 MHz Tandy 1000 system to drive, simultaneously (and just barely):
Tandy (3 PSG)
SBPro (2 digi + 18 FM)
Roland SCC-1 (General MIDI + GS)
IBM Music Feature Card (8 FM)
Internal Speaker
...and I suppose, if you want to be really sick, a GUS as well. All can be installed without resource conflicts, but driving 56+ channels may not be possible @ 60Hz due to the variable bus delays required for each card.
The biggest problem is the toolchain: How to compose music for such a monster? And, other than virt, who is talented enough to compose music for such a setup?
Reply 215 of 930, by FreddyV
The problem is that Mod Master use the DOS/UMB Memory and Monotone use the Turbo Pascal Heap.
I am obliged to reserve 90Kb of memory for the heap instead of 40Kb usually.
Then, there is 60Kb of memory less for MOD Files loading, this is huge.
I found that the Output Object init need 60Kb, and I did not found why so far:
MyOutput:=new(PPCSpeakerSimple,Init(MyPlayer,false));
Also, Monotone code increase the software size by around 10Kb.
Do you know if there is a way to modify the heap size dynamically ?
Reply 216 of 930, by FreddyV
I want to be silly and try an AWE32 on XT 😀
I need to find one with memory…..
Reply 217 of 930, by root42
I do not understand how Turbo Pascal memory management works, I only know how it works on bare metal and C. With C you can allocate as much as you like, depending on your memory model (small...huge). Why can't you tell Pascal to use the whole 640K as its heap, to the extent that it's free? Also, if you are concerned with executable size AND memory size, is putting the code into an overlay a possibility? I know that in C one can do overlays, so I guess Pascal should be able to do the same thing. This way you can load the code only when playing a file that actually needs it.
EDIT: Maybe this helps: https://secondboyet.com/articles/publishedart … slithytove.html
YouTube and Bonus
Reply 218 of 930, by FreddyV
In Turbo pascal, by default it use the full DOS memory available.
We can anyway define its size to continue to allocate the remaining memory for DOS.
I did it this way at that time to fully separate the Player code from the Pascal interface and have the same code for DOS, UMB and EMS memory management.
Also store a reference to a DOS memory block need 16Bit and 32b for the pascal.
We also need to do this to be able to go back to DOS (Mod Master can go to a DOS Shell)
I will have to do something to be able to go to 16Bit mixing, as I need 16Kb more memory for this.
Anyway, my point here is that initialize the PC Speaker Object need 60Kb in monotone core, and I seems to include only a quite small table inside.
I think there is a problem somewhere.
Reply 219 of 930, by MobyGamer
You can shrink the heap to 0 and back to the heap size by manipulating the heap pointers. I use this in TDL. I'll post example code later.
