First post, by Repo Man11
I've been having fun building a Socket 7 system since I found one in a dumpster. I bought a Biostar MB-8500TTD (at a reasonable price, too rare on Ebay these days) as an upgrade for the FX chipset board it had in it. Today I received the K6-2+ 550 I ordered, and was eagerly looking forward to installing it and testing it, but I hit a roadblock; two of the jumpers I need to close for the correct voltage and FSB are just dots on the motherboard. I think the easiest solution would be conductive paint, but in all of my years of fooling with computers, I've never used any before. Any recommendations?
Reply 1 of 11, by cyclone3d
We used to use the auto rear window defroster repair kits that you can get at any auto parts store.
Easy to undo as well.. just not sure if you need something to actually handle any amount of power going through it or not.
If it were me, I would just add the jumpers and be done with it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 11, by Miphee
Maybe solder in two pins? It only takes 5 minutes at most if you are inexperienced with the soldering iron.
Reply 3 of 11, by dionb
Jumpers for correct voltage not implemented... are you sure that's all that's missing? If the voltage regulator they connect to is also absent it won't help to connect the dots, regardless of how you do it 😮
Reply 4 of 11, by Repo Man11
For the core voltage, the last jumper is missing out of the block of four, but the position is clearly there. Without being able to close that one, the lowest core voltage is 2.8 - fine for an Intel 233 MMX, not so good for a K6-2+.
Reply 5 of 11, by nali
Car window kit was used to modify Athlon XP in Athlon MP, so it should work.
Be sure the mainboard is really compatible with this mod.
Reply 6 of 11, by Doornkaat
Simply having solder spots and traces does not mean you have the correct voltage regulator. Personally I'd look up the datasheet and test voltages before inserting a K6-Plus CPU.
Reply 7 of 11, by Repo Man11
I hadn't replaced my soldering iron after the fire, but this is a good excuse, so I just ordered one. And I just picked up a donor motherboard from the overflow heap at my nearby E waste facility.
Reply 8 of 11, by Repo Man11
I added the jumper, and all is well.
Reply 9 of 11, by dionb
As in "it boots" or "I tested voltage with multimeter and it corresponds to setting"?
P55C CPUs will generally run at 3.3V, but they get excessively hot, which is not conducive to a long healthy life.
Reply 10 of 11, by Doornkaat
Congratulations! Nice. 😀
Reply 11 of 11, by Akuma
Maybe a bit too late, but this works well and is for those non-soldering types: use a silver sharpie 😁
It conducts and can easily be removed with some alcohol.
