case fan header help
First post, by Robhalfordfan
i am building a new build and still not there yet but i am still debating with myself about cases but also thinking case fans
the case i am thinking of getting is corsair 200r which room for max of 8 fans (2x front, 2x top, 2x left panel, 1x rear, 1x bottom)
but the mobo (evga 780i) only has 4x 3-pin headers and thinking of using splitter cables but i am assuming each header max power is 1 amp
thinking of these nocuta fans for the case
https://www.amazon.co.uk/gp/product/B00KF7R49 … 5RZ72I2JQ&psc=1
which says on the label DC-12V - 1.20W - 0.10A
PSU I will be using is EVGA 650 Watt GQ Gold Hybrid Modular (which has 54a on the 12v rail)
would i be safe using the fan splitters on all 4 headers with 2 fans on each and would it be enough power on the 12v rail along with GPU - GTX 580 (which it needs a min of 600w with 42a on 12v rail)
Reply 1 of 2, by kalm_traveler
Robhalfordfan wrote:
i am building a new build and still not there yet but i am still debating with myself about cases but also thinking case fans […]
Should be just fine. Although fans use quite a bit more amperage to initially begin spinning, as you see those modern Noctuas are very low overall and you should be fine to run 2 or 3 per MB header. I'm sure that PSU will be fine though you could always opt for an even more beefy PSU if you want headroom.
Retro: Win2k/98SE - P3 1.13ghz, 512mb PC133 SDRAM, Quadro4 980XGL, Aureal Vortex 2
modern:iRyzen 9 9950X3D, 64gb DDR5-6000, RTX 4090 FE | 2019 Razer Blade Pro
Reply 2 of 2, by Robhalfordfan
Thank you for replying and will keep that in mind and will try with one fan per header and see how it goes and hopefully it will keep the build I am build cool enough, if not I will think more fan and splitters
