Reply 30800 of 57037, by dionb
jaZz_KCS wrote:
Is that an AN430TX? Seems to have a Vibra 16C and the spot for the integrated GPU seems to be vacant. It probably would have been an integrated ATI Rage II + DVD, or something similar.
Nope, that's a VX chipset. More likely to be TE430VX.
Reply 30801 of 57037, by Unknown_K
derSammler wrote:
No. :P […]
imi wrote:
stop making me all jealous 😁
No. 😜
How you like this one:
First consumer CD Recorder sold for under $1000 ($999 that is). I really love its colors.
Are you sure about that? I purchased a HP 4020i (bare drive) for around $1100 at Bestbuy and it dropped to $999 within a month (I got a rebate for the price difference). I would expect the external drive you show to cost at least $100 more then the bare drive I got.
Reply 30802 of 57037, by derSammler
Yes, I'm sure. This thing was made to be budget.
The attachment PMRCD.PNG is no longer available
You are right that the external version was more expensive. But that model was the first one to have an SRP of under $1000.
Reply 30803 of 57037, by oeuvre
I think it's a VX but yes it does have a Vibra 16C onboard.
Reply 30804 of 57037, by Repo Man11
imi wrote:
after not having luck with any of the scrap boxes full of motherboards and cpus I decided to just order one after all 😁
what fancy packaging...
It looks as though I bought one from the same seller, as mine came in the same sort of case. Not long after buying that one, Ebay informed me that a K6-2+ 533 I had looked at had been relisted at a lower price ($11.45), so I bought that one as well. Which is fine, I have two Socket 7 boards.
Reply 30805 of 57037, by xjas
^^ Oh YOU bought that 533. I was about to hit the button on it, but chickened out as I'd have to resistor-mod my P5A-B in order to get it to run properly, and couldn't decide if I felt like going to that level of messing-around on a system that's running great as-is. When I went back to check it again it was already sold. 😜
I might still grab one of those 550s from the Chinese seller. They seem to have quite a few left.
Reply 30806 of 57037, by Vegge
Some random stuff I bought over the last few weeks.
Two Socket 4 CPUs, with and without the FDIV bug.
The attachment IMG_3947s.jpg is no longer available
Some memory and cache.
The attachment IMG_4043s.jpg is no longer available
And now for the free stuff.
PCI-X SCSI card.
The attachment IMG_4013s.jpg is no longer available
And an old laptop, Toshiba T1200. Haven't tested it yet though.
The attachment IMG_4071s.jpg is no longer available
The attachment IMG_4072s.jpg is no longer available
Reply 30807 of 57037, by H3nrik V!
Wow, great condition on those Socket 4's! Congratulations on that find. I wouldn't dare putting coolers on those, with that nice condition of the printing ..
Reply 30808 of 57037, by imi
well at least some of those chinese sellers have realized these are collectibles and aren't just scrapping them all... and the prices are somewhat reasonable at least too ^^
Reply 30809 of 57037, by FAMICOMASTER
I bought a boxed memory expansion card a while back and it came in yesterday. It's a full height, full length 16-bit ISA card and it will give 640K with 4164s and 2.5M with 41256s. Of course, it's fully populated with 41256s!
I don't know anything about it, however, I can't even find record of this board. I can find a few mentions of Cheetah, but never this card itself. It didn't come with manuals or diskettes, and the box is very plain aside from the Cheetah logos. Would love to use this in my AT clone!
The box
The card
Reply 30810 of 57037, by oeuvre
woah that's a dope lookin' card... what're you gonna do with all that cache?!
Reply 30811 of 57037, by FAMICOMASTER
XMS, not cache. Unless you were talking to the guy with COAST modules, oops.
Reply 30812 of 57037, by Merovign
The T1200, like most early Toshibas, *MAY* requires a working battery to start up. *Or* you can wire around the battery - basically the charger *just* charges the battery.
Some of them (like mine) seem to and some don't - maybe the ones that don't are T1200 XLs?
Luckily C-cell nicads are still available, so you can make one pretty cheap. The batteries tend to leak but IIRC they are in a plastic tub so if it was stored flat it shouldn't have leaked onto the motherboard.
IIRC also they have a barrel-type CMOS battery which may have leaked.
Here's a manual if you haven't found it yet: http://www.minuszerodegrees.net/manuals/Toshi … ce%20Manual.pdf
*Too* *many* *things*!
Reply 30813 of 57037, by Zero_sugar
The attachment IMG_20191018_125609.jpg is no longer available
The attachment gf1.jpg is no longer available
Pretty happy to find these today. Geforce256 work as far as I can tell. The Quadro4, on the other hand, does not post. Both of the top caps show damage. Not bad for digging them out of a bin.
Reply 30814 of 57037, by dionb
Merovign wrote:
The T1200, like most early Toshibas, *MAY* requires a working battery to start up. *Or* you can wire around the battery - basica […]
I have one of those too. Not been able to get it working yet, even after attempting to fake a battery in there. Unfortunately the casing is in very bad shape (plastic just crumbles), but would very much like to get it running, its HardRAM is a feature I'd love to play around with. It actually has three separate batteries - the main one, the CMOS one and a third keeping the HardRAM powered.
Reply 30815 of 57037, by derSammler
You can simply connect a PSU to the battery terminals. That's what I did on mine when I got it and did a first test.
Reply 30816 of 57037, by piatd
These are more curiosities for a project than solutions I'll use, as they're outclassed by other heatsinks on their respective platforms:
Thermaltake Silent Tower circa 2004
The attachment DSCN5956a.jpg is no longer available
The attachment DSCN5957a.jpg is no longer available
Thermaltake V1 circa 2008. Much older brother to the Zalman CNPS 6000cu.
The attachment DSCN5960a.jpg is no longer available
Reply 30817 of 57037, by cyclone3d
Nice.. I still have the Silent Tower I bought new when it first came out. Works a bit better if there is a second fan on the other side used as an exhaust. And you can get higher cfm fans as well. The stock one really doesn't move a lot of air.
Edit: Here is one of the more interesting things I have gotten recently. I had been looking for one of these adapters for a good price for a while. It came with a motherboard, cpus, ram, and a few cards.
A Lin-Lin S370 adapter to use Coppermine CPUs in older boards as well as to use Tualatin CPUs in older boards.
The attachment adapter.jpg is no longer available
The attachment jumper_settings.jpg is no longer available
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 30818 of 57037, by Repo Man11
I recently bought a Soyo SY-5EMA+ for a non ridiculous price, and am pretty happy about that. But it didn't include a backplate. So I began looking for one, and decided that maybe I should try to find an older case, since it would be more period correct and the backplate included with older cases would work fine with this motherboard. And I found someone selling one of these on Craigslist for $15.00:
A MAXTOP Hivemind CSX-917K. It isn't new old stock (though he did have it packed back in the original box, plastic bag and styrofoam included), but it's in near perfect condition. Floppy drive included, only one drive bay cover missing, and other than the extra audio ports, the included backplate is perfect. The one in the image is slightly later, mine doesn't have front USB, but that's fine since the motherboard has no USB header just the two rear ports. There was a very long drive involved, but to me it was worth it.
Reply 30819 of 57037, by FAMICOMASTER
What does this actually do? Is it just a VRM or something?
