First post, by bionicle_159
I have the board K7S5A, I have tried four different power supplies of varying age and have not been able to get the board to post. The I know the CPU works (Athlon Xp 2600+) and the ram does as well. I have been using the voodoo 3 2000 pci primarily whilst trying to get it running but have also tried a rage 128 agp as well. The first time I powered it on the speaker went beep beep, beep beep and shut off. When I tried a different power supply it would stutter on power up (this one had 25 amps on the 5v rail) with the fan behaving erratically. I tried clearing the CMOS, then powering up and it would power on then instantly shut down. Tried a new battery and it would do the same thing. I turned it off for a few minutes to let the charge go from the caps and tried turning it on again and it now turns, on spins up and doesn’t beep or display anything on the screen.
Work Rig  - Ryzen 2700X, 16GB 3200Mhz, MSI B450 LN91340, HD 7970 Ghz (I know...), SB 1500
XP Rig - C2Q Q6600, 4GB 800Mhz, GA-P31-DS3L , GTX 750Ti, SB 0820
98SE Rig - AthlonXP 1700, 512MB 166Mhz, NForce A7N8X-X, V3 2000 PCI, Aureal Vortex 2 SQ2500
