First post, by kovacs
I'm new at these forums, please be gentle. 😀
I have a MacBook Pro running Macos Mojave.
I bought a "real" Roland SC-55 mk2 which works fine with my Mac. The SC-55 is connected via midi cable to my external audio card which has DIN Midi in/out/thru ports.
Scummvm has no problems sending all midi output to it. I simply selected the correct output port in the Scummvm setup.
However, I can't figure out what I need to do in Dosbox to make it send midi to the unit.
I don't understand what needs to change in the settings:
mpu401=intelligentmididevice=coreaudiomidiconfig=
If I change mididevice=coremidi I get no music at all.
I have tried to search but I can't find anything which explains how this feature actually works.
