Reply 240 of 925, by alvaro84
- Member
wrote:hi,
You need to use the turbo pascal CRT Fix.
I do not fix the Executable when I release it.
TP7P5FIX solved the problem too (when I tried it on the K6-2+/550 I tested this week).
And any option you prioritize please keep an eye on memory usage. On a (max) 640k vanilla XT memory is a precious resource.
Oh, talking about free memory. I've never seen DOS shell work in Mod Master. It either says not enough memory or simply hangs on loading(?) command.com. Should this work at this point at all?
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
