First post, by o0Nosferatu0o
Hi, i'm new here but i've a big question :
Is it possible to pair an AWE64 Value with a Goldfinch? My idea was to give the Awe64 Value those 28mb of Ram available to the Goldfinch.
I own both cards but right now i can only get 512k from the AWE64 Value. I've tested the Goldfinch with at least 2MB and they are not detected in Win98Se. Am i doing something wrong?
Best regards,
Pedro Torres
i.e - I do have a lot of retro hardware i'm willing to sell - that includes Boxed Creative Capture Cards, graphic and sound cards but for now i'm not intitled to get to a sales thread.
Reply 1 of 5, by jheronimus
Goldfinch is actually a standalone Wavetable/General MIDI device. Basically AWE32 without a Soundblaster and other features. So there is no point using it together with AWE64. Also I don’t think there’s any way for AWE64 to access the memory of Goldfinch.
Ideally just pair Goldfinch with some SoundBlaster 16 or a clone and use an AUX cable to route Goldfinch’s output into SB16’s line in.
MR BIOS catalog
Unicore catalog
Reply 2 of 5, by o0Nosferatu0o
Hi jheronimus, thank you for your reply. I'm going to try it with an Audician and see how they get along.
Reply 3 of 5, by jheronimus
Yes, Audician should be a perfect match — better than your AWE64 in many regards.
MR BIOS catalog
Unicore catalog
Reply 4 of 5, by gerwin
Yes. AFAIK The whole point of the on-card memory here, is to avoid the ISA bus when accessing soundfont samples during midi music generation. The ISA bus is too slow for this.
Reply 5 of 5, by SirNickity
If you have a wavetable expansion header on your sound card, you can use a simple ribbon cable to connect them internally. That way you don't use up your CD audio connector, if you only have one and want to use it with a CD-ROM.
