Reply 13300 of 31218, by keenmaster486
Set up my new Thinkpad T41 to dual boot LUbuntu and Windows XP SP3. So far it is working well!
World's foremost 486 enjoyer.
Reply 13301 of 31218, by Tiido
SSTV2 wrote:
440LX won't work with non 1/2 FSB PCI bus dividers, intel chipsets doesn't support asynchronous PCI bus mode, unfortunately. If AGP card checks out, then most likely some device on the PCI bus causes system instability as 41.7MHz freq. is way over the specs for it.
Then that source of instability is the southbridge, since that's the only other PCI device left during my testing. All other cards besides video that I plan to use in the machine work fine at 50MHz PCI even. I have ruled out power supply issues, there's no meaningful ripple at any rail present in the system and everything is within tolerances.
Reply 13302 of 31218, by SSTV2
That is very well possible, you could try bumping 3.3V Vcc to about ~3.5V for the whole chipset, stability should greatly increase then.
Reply 13303 of 31218, by Deksor
Page 666 😈
Anyways, @Predator99 I'm currently trying to do the same with two Seagate ST277R and a Tando TD 362, but so far no luck (and the bearings of the head mechanism are starting to fail on the tandon, so the head don't move as far as it should go on the disk ...)
Reply 13304 of 31218, by Turbo ->
Repaired traces, replaced crystal oscillator and two transistors on an 286 motherboard, that refuses to count BIOS time.
Reply 13305 of 31218, by HanJammer
Finally cleaned up this Turbo XT machine I bought recently (after cleaning this machine is almost immaculate - certainly less dirty than my modern PC 🤣)... browsed through the HDD (it seems between 90 and 94 it belonged to some PhD lady from Warsaw University of Technology - a lot of scientific stuff and her projects) and paired it with recently purchased monitor...
Reply 13306 of 31218, by HanJammer
Oh! I have very similar motherboard an simiral problems, but in my case - it counts time too quickly (like skips 2-3 seconds instead of 1)... Similar dammage too... I replaced ceramic caps which were cracked, but it didn't helped... which oscillator you replaced?
Reply 13307 of 31218, by SSTV2
^ Kick-ass combo.
Reply 13308 of 31218, by Turbo ->
14.31818MHZ - usually 286 motherboards had oscillators with such frequency.
Reply 13309 of 31218, by FAMICOMASTER
Set up my trusty EGA Wonder card to test out my color monitor some more. Unfortunately, it doesn't seem to work with EGA resolutions (400 lines), but it works BEAUTIFULLY as a normal CGA monitor. The EGA board can display 16 glorious colors simultaneously on it. I think the EGA Wonder is even doing some hardware magic to get more colors out of it - At least that's what the manual seems to imply. It will even run some EGA software without losing sync!
Either way, it produces an excellent, bright picture with great contrast.
Now I need to get the buttons on the front of this monitor working. Anybody know how to work on these things? The 4 touch sensitive buttons on the front don't seem to work at all. This monitor definitely needs a good cleaning and retrobrite too, the yellow is really ugly.
I'm also wondering... Is it possible to modify any of these monitors to take an EGA signal natively? I'm sure there's a mod out there somewhere that can change the frequency to a wider range.
If it is possible, I might mod this one while I'm restoring it, and pick up the other one I know is for sale to use in it's original configuration.
Reply 13310 of 31218, by Horun
Agree, the smaller oval shaped xtals back then were the 14.31mhz ones. And your Turbo XT looks great !
Reply 13311 of 31218, by Caluser2000
Maybe some thing disconnected or gunge preventing contact. Odd they are all not working though.
Reply 13312 of 31218, by FAMICOMASTER
I know they're not disconnected, because if the monitor is on and warmed up, switching the computer on will put it into a random mode and the "Mode" button will work 2-3 times and then it will quit. No other buttons will work, though. I've cleaned them numerous times with different chemicals but nothing changes this operation.
Also, the monitor can sometimes just switch modes at random and flicker between colors.
Reply 13313 of 31218, by MMaximus
Nice monitor! Have you used the EGA wonder driver disk to switch modes on the card? The EGA Wonder 800+ can display EGA hi-res modes on a normal CGA monitor, thanks to interlacing. I would assume the standard EGA wonder can do the same thing...
Hard Disk Sounds
Reply 13314 of 31218, by wiretap
Take out the button controller and replace all the components on it, especially any electrolytic capacitors. (even if they look fine) There is a ground reference that is becoming elevated -- this is why it seems to work initially, then quit, and why it can change at random.
My Github
Circuit Board Repair Manuals
Reply 13315 of 31218, by derSammler
Nothing that special, but since I have many loose HuCards for the PC Engine, I quickly made a 3d-printed sleeve to hold 7 HuCards in place. Turned out quite well. 😀 (ps: why 7? because the number of HuCards I own is a multiple of 7)
Reply 13316 of 31218, by yawetaG
Before doing that, replace the buttons themselves ( the switch part, not the button caps). They can wear out, and not switching on anymore is the usual symptom.
Reply 13317 of 31218, by yawetaG
As for recent activity, opened up my Zoom RT-323 drum machine because the slider was a bit glitchy, blew the dust out, and took some pictures of the internals (it has a battery soldered to the motherboard). Turns out the thing uses the Zoom ZSG-2 DSP/wavetable synthesizer chip, which is also found in many Taito arcade machines 😲 . Well, at least that explains why a drum machine with very little sound editing capabilities has sine, saw, and square wave patches, and also some patches that clearly use two different components that normally should be beyond standard drum machine fare...
Reply 13318 of 31218, by HanJammer
Yeah, but there are 3 oscillator on this board... OK, so the one which is heavly corroded in mine...
Reply 13319 of 31218, by FAMICOMASTER
There are no switches, they're touch sensitive. You don't push on them - You touch them. The black line is the separation between the contacts.
If I could get the damn thing open I'd be better able to check them.
