Reply 260 of 467, by matze79
ET4000 issues solved..
The attachment ET4000 compatible.jpg is no longer available
Time for a Break.. =)
Reply 261 of 467, by root42
Bodge wires are always a good thing. 😉
This looks like a rather small modification! Good job!
YouTube and Bonus
Reply 262 of 467, by matze79
Fix for graphical glitches with some cards..
Reply 263 of 467, by matze79
The attachment fix.jpg is no longer available
Reply 264 of 467, by matze79
4D Sports Driving - Recording Test with Zoom Q2n (Thanks Dreamblaster!)
https://youtu.be/ejSy6LPTeEk
Using PC-Speaker In too to achieve 4 Voice Sound.
Reply 265 of 467, by matze79
More News, Testing Software and TSR development continues 😀
TSR:
The attachment dosbox_011.png is no longer available
Fully featured Testing Programm for 3 Voice Chip:
The attachment testtndy_001.png is no longer available
Reply 268 of 467, by bjwil1991
I have a Lo-Tech Tandy 3-voice card in my 486 and when I run King's Quest 2 or the Sierra On-Line demo programs using the Tandy voice, I have graphical glitches. Other King's Quest games, including Space Quest 1-2, and Police Quest EGA are working fine.
Reply 269 of 467, by matze79
You need to add 2k2 Resistor from READY to VCC on the SN76489.
The LoTech Card is missing the PullUp for SN76489.
Also add the 68pf as shown above to reduce noise a bit.
Maybe this will fix your issues ?
Reply 270 of 467, by bjwil1991
2k2 is 2.2K Ohms, right? Also, about the PC speaker mixer for the card. How can I get that to work? I can only get a standard 8 Ohm speaker to work or the squeaker cam speaker and I would like to direct the PC speaker to the Tandy card, and the volume is turned up as well. I will give this a go soon as I need to buy those components on Digi-Key.
The hotfixes are on page 13 the first post of where they need to be soldered onto, correct?
Reply 271 of 467, by matze79
Tandy 3 Voice Sound - SN76489 ISA Soundcard Project
Yeah 2k2 kOhms
The PC-Speaker in of the Tandy Card works on some Machines but not on all, you should get it working if you link the signal in with a capacitor.
otherwise it will result in a short circuit and maybe damage something.
i don`t have the original lo-tech card anymore 😒
This is used on some SB Vibra Cards:
file.php?id=61123
Normally any Speaker should work on the Speaker Output, but if its too silent you can connect a 10uf Capacitor from Pin 1 to Pin 8 on LM386 to rise the gain to maximum.
Reply 272 of 467, by Scali
Okay, that's interesting. I had not run into any graphical glitches yet with my card, but apparently it only occurs with some software (makes me wonder why). I'll test my card specifically with KQ2 and see if I get the glitching as well.
Reply 273 of 467, by bjwil1991
matze79 wrote:
Tandy 3 Voice Sound - SN76489 ISA Soundcard Project […]
Yeah 2k2 kOhms
file.php?id=61123
Thank you. I will buy some caps and resistors and fix the issues. My GPU is a Cirrus Logic CL-GD5428 VLB integrated on my Packard Bell Pack-Mate 28 Plus. Also, would it be a good idea to use a 47pF capacitor over the 68pF? There's a MicroCenter in my area that sells lots of resistors and capacitors, but no 68pF ones.
Reply 274 of 467, by Tiido
47µF will help but not as much as 68pF will. 100pF will work but probably begins to muffle sound. Two 47 is series and then parallel over 3rd 47pF should get something around 70pF which will be fine.
Reply 275 of 467, by Akuma
I've been following this topic for a while, although I personally do not like old hardware, this topic is awesome !
Thanks for sharing 😁
Reply 276 of 467, by bjwil1991
For the series, that means the two are connected to each other and parallel means opposite ends connect (ex: AA battery compartments)?
Reply 278 of 467, by bjwil1991
I added both the caps (3x 47pF caps to be ~70pF) and the 2K2 resistor and I still have graphical glitches in King's Quest 2.
Reply 279 of 467, by matze79
Do you also have Graphical Glitches with PC-Speaker ?
Do you run Card on XT or AT System ?
If you don`t have glitches with PC-Speaker and If you run on 386 + do you also get glitches if you run with TNDY.COM TSR with the Card located on other Adress ?
Add least you will no longer suffer from compatibility problems with sound blaster cards (Non-16) with the 2k2 resistor 😉
