First post, by pixel_workbench
While messing around with an S3 Virge DX and torturing it with various old 3D games, I found a way to make it display world textures that are typically missing on the Virge decelerator.
Launch the game with the developer console enabled. By default the Virge will only show lightmaps instead of the world textures.
94.04 KiB
Now open the console and type:
gl_monolights 1
- then reload the save game. This will enable the Virge to display world textures.
283.27 KiB
While the textures are showing, the side effect of this tweak is that the lightmaps are now completely black, creating harsh shadows. To fix the shadows, simply remove them completely 🤣 Open the console again, and type:
r_fullbright 1
- this forces all textures to be rendered at full brightness, and as a bonus, the Virge gets about 100% improved performance from not having to do multi texturing.
271.87 KiB
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 1 of 4, by xjas
I kind of like the no-texture version. Is there a way to enable that on more competent GPUs?
Reply 2 of 4, by leileilol
Typically that's a cheat/developer cvar in standard id tech 2/3 (r_lightmap 1)
Also these virge screens appear to come from the D3D backend. The Techland S3 MiniGL found in Crime Cities seems to do a better job (PCem shot follows)
221.77 KiB
Other useful cvars:
gl_round_down 1
gl_lightholes 0
gl_spriteblend 0
Reply 3 of 4, by 386SX
I wish I knew this when I had the Trio3D AGP with the K6-2 350 to not buy the Voodoo3 2000 I didn't really need considering everything would have still run ok with every accelerators since the Voodoo1 back then. Back in those times I could have played games even at few fps considering the previous config I had was the 386SX-20. 😁
