First post, by FeedingDragon
Actually struggled with this for quite a while. The loud "pop pop pop" sounds were rather annoying. It happened both in DOSBox and on my vintage system. The thread there is 8 years old or I would have posted on it, to see if anyone had found a fix for it. Well, to make a long story short, I managed to get rid of the pops in both DOSBox and on my main system by switching from the DOS4GW version that came with it to DOS32A. I ended up patching the exe files themselves to use DOS32A natively. There may be another, or a better, fix. But if there is, I can't find it.
So, it's now playing well for me, but I found the process a bit of a hassle. Being a bit of an amateur programmer, I decided to write a quick installer for it that would install, patch, & clean up. What started as a short little C++ program, ended up a rather involved project. I ended up writing a duplicate of the installer that the original Eye of the Beholder III, and it's v1.2 patch, used. Actually learned a bit in the process 😀 I also cleaned up the centering a bit. Straightened out a bit of visual inconsistencies, and such. It still looks much the same, just a little better 😀 I could have actually used the original install engine, the install.nfo file is rather simple and easy to duplicate/edit. However, it didn't allow for the necessary use of other programs to convert resource files (and you need to convert the ones that are current to your version.) It also didn't allow for cleaning up the excess.
So, without further ado. The final product, packed up in the same format as the original. Provided is a zip file with a WinImage image file and a folder with just the install files themselves. At 540K for the zip, I didn't think it would hurt to just pack both formats together. Usage is simple, write to a disk. Install EOB3 normally. Then insert the AESOP 32 disk and type install. Follow the directions 😀 Just like the original install program for EOB3, and it's v1.2 patch, at the end it will run the sound setup program. Though, you can cancel that by hitting ESC (twice) when the message that it is installed correctly appears 😀 Have fun, and tell me what you think.
Also NOTE: The patch replaces several files and doesn't make backups. It also deletes files that it no longer needs when it's finished (like daesop.exe, 3h.bin, etc...) Once it's installed, the only way to go back is to re-install the game. If you are unsure, make a backup before installing the patch. I personally, don't have a problem with patches that work this way as almost all, (well all that I've ever used,) official patches also work like this.
p.s. The thread here is locked or I would have posted this there 🙁
    aesop32.zip
    539.57 KiB
    263 downloads
    Eye of the Beholder III, Aesop 32 patch
Feeding Dragon
Reply 1 of 14, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Not sure what you were struggling with for so long, as you only have to put DOS32A.EXE renamed as DOS4GW.EXE in the game directory...
Some time ago I found a workaround for the popping sounds when using DOS4GW as the extender, which at least works in DOSBox 0.74 and SVN with default settings, is to allocate a single page of EMS memory before running the game. It seems the popping is related to DMA, and using EMS where the allocated number of pages is NOT an integral of 4 prevents it. The game doesn't need EMS, this workaround just manages to avoid the problem. However, DOS/32A is a more off-the-shelf solution.
Reply 2 of 14, by keropi
this thread highly interests me! 😁
I've been wanting a working "32bit" EOB3 since the game was new, there was even a flyer inside the game that promised the new 32bit engine will be released soon as a patch and it would be awesome... alas this never happened.
I did mess with the previously released aesop32 engine and was getting the the annoying pop sounds... tbh I didn't notice anything faster on my p200mmx system - maybe the difference is more apparent in slower systems...
At any rate thanks for the extra info on this, will give it a spin and report back!
🎵Link to buy a PCMIDI mpu
🎧Orpheus soundcard project
💻WTB Amstrad PC7486SLC-33 system
Reply 3 of 14, by FeedingDragon
I was struggling with finding a fix in the first place. Not with replacing DOS4GW. As you said, just replacing the EXE is the easiest method. I just updated the EXE files so that other don't have to worry about it (if they use my installer.) Finding out that the DOS4GW extender was causing the problem was an accident. My modern system (the one connected to the internet,) was offline for a bit, and I had deleted DOS4GW accidently. So, I grabbed DOS32a from another game I use it on (also had issues with DOS4GW,) and used it instead. Was rather surprised when the popping (which wasn't as loud on my vintage system as in DOSBox,) was gone.
That's when I started experimenting, and later started writing the installer.
I use my own build of DOSBox, but had the same problems in both 0.74, the SVN, & the DAUM build. What is interesting is your phraseology suggests that DOS32/A doesn't work with those. I haven't had any problems in any of the builds I tried (.74, latest SVN, my own build, or DAUM.) Even on default setting. About the only issue I've found is some times when I exit, DOS32a reports that a vector has been changed. Not an issue in DOSBox. Been meaning to look into it later, because I primarily play these games on my vintage system.
Feeding Dragon
Reply 4 of 14, by keropi
Just tried both methods: renamed dos32a.exe and FeedingDragon's patch, they both worked the same 😀
@FeedingDragon
is your patch modifying EYE.RES as well? there are certain annoying bytes there no longer in the same place... 🤣
Reply 5 of 14, by FeedingDragon
@FeedingDragon
Yes, it applies the full Aesop 32 patch... That is, it de-compiles the eye.res file, builds the 3h.bin file, then re-compiles the eye.res with the new 3h.bin file. Then it cleans up after itself. You probably noticed the large amounts of quickly scrolling text as it de-compiled re-compiled the file.
Feeding Dragon
Reply 6 of 14, by ripsaw8080
Rank DOSBox Author
DOSBox Author
DOS/32A does work in DOSBox. I have no idea why you thought what I wrote suggested otherwise...
That's normal behavior. You can set an environment variable (e.g. "SET DOS32A=QUIET") to eliminate warning messages if they're annoying you.
BTW, what is superior about the 32-bit interpreter compared to the original 16-bit interpreter? Never was able to figure out what the attraction is...
Reply 7 of 14, by FeedingDragon
The line, "when using DOS4GW as the extender, which at least works in DOSBox 0.74 and SVN with default settings" sounded like DOS4GW works while others don't. At least that's the way it came across to me. Re-examining the line, I guess you meant that the "fix" works in at least those versions of DOSBox.
Going to edit my original post.... Been thinking about it, by cleaning up, I mean that unneeded files are removed/deleted. So, once it's applied, the only way to go back is to re-install. I don't have a problem with that myself, as I have both the floppy version, and a couple of CD versions (compilations.)
As for what the update does.... I'm not 100% sure. I do remember that when I first played it, I had problems with crashes and such. This supposedly reduces that. I haven't gotten back to EOB3 yet (still re-playing EOB1.) I'll find out more when I get to it. From what I read, the Aesop 32 version is primarily more stable, and has smoother game play later in the game. I never got that far in it before (too many crashes,) but I've read that later in the game it starts to really bog down, and this supposedly fixes that.
Feeding Dragon
Reply 8 of 14, by FeedingDragon
The message itself doesn't bother me, it's just that I didn't know exactly what it means. I did some searching, the vector changed was for IRQ 5 (my SoundBlaster is there,) so I assume it has to do with the way the game is handling sound. Less worried about it now 😀
Feeding Dragon
Reply 9 of 14, by keropi
yep, sorry about that eye.res , I forgot it gets converted as well... I did see the scrolling info 😁
the only thing I noticed with the AESOP32 patch is that you no longer need EMS for the sfx or something. Running stock EOB3 without EMS makes it complain about sfx not being able to play... otherwise I too have no idea what is improved, speed-wise they seem the same on a fast machine.
What I wish is that someone could treat EOB3 like EBO1/2 were treated by CFOU! : http://eob.wikispaces.com/EOB2+AGA+GAME
basically the amiga versions became the best ones with the new automap feature...
Reply 10 of 14, by FeedingDragon
I would love to see EOB3 converted to the Amiga. I actually liked the Amiga versions better than the PC. Especially if I could also port the MT-32 music as well.
Feeding Dragon
Reply 11 of 14, by keropi
I also noticed that AESOP32 eob3 freezes after a while if you have smartdrv write-behind cache option enabled. Remove the write-behind option and all is good.
Normal AESOP16 version does not have this issue.
I did some more testing, AESOP32 version does work faster on my p200mmx , I was wrong before when I said there is no difference. 😒
Reply 12 of 14, by FeedingDragon
I was about to post that it hasn't given me any such problems.... Then I double checked, I turn SMARTDRV off. With the hard drives I have installed it doesn't make that big a difference for DOS games, and this gives me more RAM to play around with. Was never a big fan of write caching anyway. Read cache, yes, but not write.
Feeding Dragon
Reply 13 of 14, by keropi
well, if you have ram to spare (like me) then some write cache is good when you create/decompress archives or use ftp to transfer files ... not a biggie though, write-behind can be switched on the fly
Reply 14 of 14, by Mithloraite
That's great EOB3 got some attention! Might you know a way to compile a EoB-1 portrait (31x32 .bmp) into EYE.RES?
Many tools allow to get the original EoB-1 portrait from .cps file. I did it. But how to convert it into EoB-3 palette?
I know XWE (last beta) decodes EoB-3 portraits with EoB-3 palette. But it doesn't allow saving anything in this format.
Perfection is the key. Fatality is the key. (c)
