Reply 360 of 555, by LABS
After a compelled delay I want to announce some upcoming updates I'm currently working on:
  • In-system MCU flashing directly from DOS environment
  • Ability to load 16Kb of custom AVR code to MCU and use it as a co-processor or a DSP
  • Flashing utility for DOS (flash-bb.exe)
  • BB diagnostic / testing utility (test-bb.exe)
  • Documentation for all mentioned above 😵
  • Some minor firmware compatibility fixes
In-system flashing will be available with next firmware release (3.0). However, updating to version 3.0 requires an external programmer. Preprogrammed MCUs with v3.0 will also be available separately at the cost of shipping.
Blasterboard: DIY SB2-compatible sound card on ATmega MCU
Sonic Buster 8: New 8-bit ISA sound card
Reply 362 of 555, by keropi
LABS wrote:
After a compelled delay I want to announce some upcoming updates I'm currently working on: […]
Reply 363 of 555, by onre
Looks like this would be a perfect fit for a Toshiba T3200SXC. Are there kits available as of now? I tried sending a PM, but apparently I need to post more before that's possible.
Reply 364 of 555, by LABS
pm
Reply 366 of 555, by LABS
FreddyV wrote:
Hi, […]
When I am soldering my board, the Capacitors C28 and C28 are reversed compared to the picture come page before.
Is it normal ?
C28 Grey 1nF
C29 White 10nF
For Rev B boards C28=1nF and C29=10nF, colors could differ from kit to kit
Reply 367 of 555, by 640K!enough
Out of curiosity, did you take the bootloader approach when implementing self-programming of the MCU, or was there a solution you liked better?
Reply 368 of 555, by LABS
Yes, it happened that with a bootloader mcu can be reflashed without introducing any hardware changes
Reply 369 of 555, by FreddyV
did you think about what I proposed you ?
Implement the 8 bit Sound Blaster 16 commands : Set Frequency, 8 bit High Speed DMA signed.
It is "Only" adding existing commands that "No" software will use as the board is seen as a SB 2.0.
This will allow to setup the frequency more precisely and speedup mixing (No more unsigned)
Reply 370 of 555, by LABS
FreddyV wrote:
Hi, […]
Sure, it is already done in fw v3.0. However, the fw is not finished yet.
I'll compile a version for you just with these commands, so you could test it with your player. Most likely after the holidays.
Reply 371 of 555, by FreddyV
I finished the board and it worked the first time I plugged it in my PC1640.
Unfortunately, I removed it to change the IRQ and it does not work anymore. 🙁
I tries to remove / Plug back multiple times and to clean the ISA Slot, it still does not work.
(Not Detected by Mod Master and other apps)
The adlib part is still working.
Will you do new batches ?
Reply 372 of 555, by Cyrix200+
FreddyV wrote:
Hi, […]
That's unfortunate, but that might be fixable. My first thing to try would be to check/re-flash the MCU. Others might have much better ideas than me though 😀
1982 to 2001
Reply 373 of 555, by FreddyV
Yes, Check the MCU, but I suppose I need special hardware for this.
I have an universal programmer (I never used it yet), a TL866, can it be used for this ?
Or I send the board back to LABs so that he check it.
Reply 374 of 555, by Cyrix200+
TL866 should work. I am not at all sure it's a useful thing to do at the moment though. You could put in the MCU and try to read it with the TL866 and see what happens...
1982 to 2001
Reply 375 of 555, by FreddyV
Hi, In a picture, I see that there are 2 jumpers on the IRQ Part.
I don't know how they are supposed to be configured.
Anyway, it was working before, the problem is not there.
1.11 MiB
Reply 376 of 555, by Cyrix200+
FreddyV wrote:
Hi, In a picture, I see that there are 2 jumpers on the IRQ Part. I don't know how they are supposed to be configured. […]
matze79 had similar problems: BLASTERBOARD : A new SB 2.0-compatible ISA sound card
Also check all solder connections, clean of flux from board.
1982 to 2001
Reply 378 of 555, by LABS
FreddyV wrote:
A dit stopper To work after i removed it To change the IRQ i dont thinking is a Soldering problem
IRQ settings are printed next to the logo, so on your photo it is set correctly to IRQ 7. Does it work on your previous setting?
Please PM me with a photo of a solder side.
Reply 379 of 555, by matze79
Yeah my MCU was dead, because of power supply issues, i replaced it with a new one which did the job just fine 😀
i tried to rewrite the old one with the TL866, but it had verify errors, flash failed.
