First post, by stormfrog
Ive been trying to make a fraps video of Alone in teh Dark 1 Intro. Its just doesnt seem possible. I can live without recording the sound so I shut that off. I putCPU cycle really low or reall high, doesnt seem to matter. I have to set render to opengl/dd since fraps cannot capture any of the other render modes.
Every time I try to record with fraps DosBox is sent into a stuttering crawl thats rather useless. I guess I could record a huge fraps (I am guessing it would take 25-30 minutes show the intro + fraps rec. Normally its only a few minutes... ) and then speed it up in VirtualDub. And then add music later through DosBox own caputing tool.
But thats alot of fuss! 😁 Anyone got a bag Voodoo tricks for this one?
Thanks!
PS And damn, DosBox is teh shite! roxxor! 😀
Reply 2 of 8, by Reckless
A quick question on the video capture built into DOSBox. From what I've read it uses 'yet another' codec - any chance of it being able to use something that already exists on the PC?
Perhaps I should add the 'request' to the DOSBox plug-in ideas thread 😀
Reply 3 of 8, by `Moe`
The codec is efficient, lossless, freely available and could be packaged with dosbox -- where's the problem?
Reply 5 of 8, by Reckless
DosFreak wrote:
Yeah, and you can always use virtualdub to convert it into another codec.
Codecs are just a means to an end but choosing one that [to me] is actually fairly unknown is almost certainly going to lead to video files being converted before being exchanged or explanations on how/what to do with a codec download in order to watch the vid. Obviously that's a possibility whatever codec is chosen but some are more used than others.
Anyways, it was just an observation...
Reply 6 of 8, by `Moe`
I'd agree, but this codec seems to be a perfect match for DOSBox in terms of efficiency and speed, so there are strong arguments for it. I think the windows installer should automatically install the codec, so there would be few interoperability issues - I guess most people who are interested in such videos have dosbox themselves.
Reply 7 of 8, by Notavi
But since the codec is lossless, only the re-encoding will cause any loss . This way the people releasing the video have complete control of codec choice (re-encode into what's needed) and can tweak the output to suit themselves.
If you're making a vid, this shouldn't be too burdensome.
Reply 8 of 8, by vilse
If you still want to use fraps, just change output mode to opengl and it should work.
