First post, by Haper
I've downloaded the latest version of DosBox - 0.65, but now with
output=ddraw or output=opengl in fullscreen mode I don't have a good smooth picture like in 0.63 version:(
System: WinXP Pro
GF4Ti 4200 (Forceware 81.95)
AthlonXP 2000
Reply 1 of 8, by eL_PuSHeR
You may have forgot to configure core and cycles as well.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 8, by gulikoza
0.65 no longer uses hardware scaling when normal2x is selected. You have to use windowresolution or fullresolution to get hardware scaling (and scaler=none)...
http://www.si-gamer.net/gulikoza
Reply 3 of 8, by Haper
It's works!
Thanks!
Reply 4 of 8, by Darkfalz
This was a pretty poor change. I don't want to try OpenGL again though since I got a hardware reset last time I tried. So much for free triple buffering... 😐
Reply 5 of 8, by Haper
Yes, you are right...
Actually, this last changes creates some new bugs
one of them in Pinball Fantasies...
Reply 6 of 8, by butterfly
That's a real shame though. It was so... smooth
Reply 7 of 8, by Darkfalz
It's obviously too late now but something like normal2xh (h for hardware) would have been a good idea.
You can specifiy 640x400 then then 320x200 will be doubled and filtered, but then what about when you want to run a 640x480 game?
Reply 8 of 8, by gulikoza
I added hardware2x and 3x in my builds 😀
But I've noticed something yesterday...windowresolution will keep the aspect ratio, so if you specify 640x480 - a 320x200 game will run at 640x400 not 480. This does make windowresolution behave somewhat like normal2x before 😁
