First post, by akm
A while back I acquired a mid-90s IBM Pentium machine. I am trying to connect it to my home network (intermittently - I won't have it always connected), but am having some issues.
I am using a Linksys Ether16 LAN ISA card with both an ethernet port and a BNC port (see below). The installation process seemed to go well - the lights are lit, and Windows 95 identified the device as an NE2000 card and it installed the driver. I then connected the computer to my home router with an ethernet cable.
All looks well, but I keep getting errors saying that Windows can't contact the DHCP server to get an IP address. it doesn't seem to be connected to my router at all - there are no additional lights on the router and my router's software doesn't see any new devices on the network. I attempted pinging google.com ('destination unreachable'), the IP of another device on my network ('destination unreachable'), the IP address of my home router ('destination unreachable'), and the loopback 127.0.0.1 (worked).
Interestingly, when I disabled DHCP in Windows and assigned it an IP address and subnet mask then reserved that IP in my router's software, my pings of my internal network devices came back as 'request timed out.' External pings still said 'destination unreachable.'
What am I missing? I've uninstalled and reinstalled the card and driver, installed Windows updates, and much more. I can't see anything that would be preventing it from connecting.
Thanks in advance!
Reply 1 of 5, by k6_cookie
Trying several ethernet cards from a wholesale of old/unkown working status some had the same issue, The bios and linux would recognize them but they would not conect.
All in all your card is dead, not sure if theres anything you can fix it but the ones that were dead on my side would often lit up when you plug the cable but the led would not blink, it would be always on, see if yours does the same. It would not blick even when you do network stuff where you'd say it sent some packets or something so it should at least responde.
Network isnt only TCP/IP, you have a bunch of layers before that, the one that seems to be failing is the lower one, the ethernet layer, meaning the card itself cant establish a link over witch to transmit the data, thats why even if you set the ip manually you dont get a response because the card isnt transmiting. Does it actually detect the cable when you plug/unplug it? Some of my cards would also show it was plugged even when no cable was actualy plugged
Reply 3 of 5, by Warlord
Did you bother to update the TCP/IP stack in 95. The other problem is that it won't work on a gigabit switch or router, since it is 10 mbit, it won't negotiate.
Anyways yea its pretty terrible card, I either do 3com or intel or nothing.
Reply 4 of 5, by akm
Thanks all for the information. I tested it further by plugging it into my 10/100 switch and the lights didn't come up on it either. Thinking the card may indeed be dead.
I put in an Intel PCI card and that seems to be working without issue.
Thanks again for the advice.
