Repo Man11 wrote:I also scored an HP 8300. I5 3470, no memory, no video card, no hard drive, but the DVD drive was still there. It also had a Win […]
I also scored an HP 8300. I5 3470, no memory, no video card, no hard drive, but the DVD drive was still there. It also had a Windows 10 key sticker on the top. I had been planning on using a G41 775 motherboard I had for the gaming computer I'm giving my cousin, so this was a big upgrade (Q 9505 to I5 3470!). I installed an SSD, the DDR3 I already had, and the video card. I had to buy a cable adapter to go from a PCIE drive connector to a six pin video card connector, but that was easy to find. I considered doing a case swap, but you have to buy a special adapter to go from a standard PSU to the connectors for this board, the heatsink is non standard and uses the case's back panel as a backplate, and the I/O plate is integral to the case; I decided that for free, he'll have to be satisfied with it as is.
It did have a strange delay when you would restart it, just the sort of thing you would expect a BIOS update to fix. But when I tried updating the BIOS, it had no effect - I then discovered that it hadn't actually updated the BIOS because I was at 2.01, and you have to update to 2.99 before you can update to the latest one. Two updates later, it's fast both in initial power up, and restart.
I found the HP 8300 because I had gone back to find the stand for this one, a Dell Inspiron One 2020. I initially though this was just a monitor, then I saw that it had USB ports, and realized that it was an all in one. It had been split open to remove the hard drive, and I saw no stand, but I took it home anyway. I plugged in my laptop's power supply, and it powered right on, so I then decided to go back to see if I could find the stand - I had no luck that evening, but I did find the 8300 behind a big screen TV. I came back the next day, and in the light (and knowing what it looked like after a Google search) I found the stand.
Unfortunately, the hard drive caddy was missing, and it's a structural part. Fortunately, I found one on Ebay for $10.00 shipped. I doubled the memory by filling the empty DDR3 slot with a 4 meg SODIMM from a laptop I found in my apartment complexes' dumpster, and I bought an inexpensive SSD. I installed Win 8, and upgraded it to Win 10, and the plan is to give it to a cousin.
