First post, by Redgeneral
Can munt run well on a Raspberry pi 3 A+ (quad core 64-bit SoC @ 1.4GHz and 512MB RAM) ? I've seen it run on 3b+ on youtube, but that has more ram.
My hope is that I can plug a usb midi keyboard into the pi and have the classic sounds available. Perhaps with a dac & lcd card (https://shop.pimoroni.com/products/pira ... stereo-amp) on top to select instruments.
Reply 1 of 2, by gdjacobs
Munt is not particularly RAM limited. Of course, if you want to use a sample based synth as well, you'll be unable to use some of the huge soundfonts that are out there.
