First post, by Cyrix200+
- Oldbie
Start here: http://www.kva.kursk.ru/bios1/numbersami.shtml
"ZZ1266" = MODULA TECH. CO., LTD.
I decided to do the Stason list of 386 boards from top to bottom to see if I could find it. The SIMM slots on the bottom are pretty unique.
Should have started from the bottom 😉
This is it: https://stason.org/TULARC/pc/motherboards/U/U … 6-UM-386SX.html
1982 to 2001
I have the same board as you, but oddly enough mine has a Aquarius bios instead and no indication on the PCB
added picture/bios here:
https://www.ultimateretro.net/en/motherboards/5397
does it POST?
Sometimes, the bios string reveals a bit more.
I like jumpers.
Board has been identified properly
