Reply 31580 of 56707, by arncht
- Oldbie
wrote:wrote:how it compares to the arklogic in dos?
i give up the trio/virge cards - the visions have better output quality with the dedicated dacs.Unfortunately, I don't have any VLB ARK card in my collection. My experience after testing about 10+ different VLB models is that DOS performance is exclusively a function of interface speed. If you use 1994+ chip and as soon as the memory bandwidth is faster than VLB speed (which it always is when you have interleaved 32bit or 64bit interface) and you can keep VLB without waitstates the performance is about the same which is also likely the limit of my VLB bus. Out of my 10 cards 5 produce almost identical performance in DOS. Windows (and to some extent linear VESA modes) at high resolution is a different thing - there are major differences even within 64bit tier.
i found the same, except the ark 😀
https://docs.google.com/spreadsheets/d/1eXksI … dit?usp=sharing
