First post, by gordesky1
So i been messing with my old 430cdt again:) But really i cant do much with its 1.26gb hdd that it has in it 🤣... And it is a great dos and win95 retro gamer:)
Is it possible to clone the drive and clone it too a bigger hdd like a 20gig? Tho i do have some 6gigs i can use tho. Right now its using fat for the file system.
The cloning software i usely use is true image which i did make backups of my other laptops which runs 98 but i never tried cloneing them and stuff. Nor never tried windows 95.
Reply 1 of 1, by Violett'Blossom
gordesky1 wrote on 2019-12-30, 02:45:
Hello, the BIOS limitations on those are 8 gigs if I recall correctly, however I would like to suggest that you use CF to IDE or M.2 SATA to IDE for longetivity and also almost 0 access time.
Cloning smaller drive onto bigger is no problem, I have been using clonezilla for such stuff, however sometimes clean install is way better since sometimes the drive won't boot afterwards.
Hope it helps.
XP machine: Phenom II X4 965, 4890 Crossfire
Main: TUF Dash F15, I7 11.gen, RTX 3060 6GB
