First post, by Fire&Ice
Hi there.
I'd like to make a little suggestion for the marvelous tool called DosBox:
to make a copy/paste ability in the window of DosBox,
(by right-clicking, or by pressing Ctrl+C/V or Ctrl+Ins/Del)
It would be really useful when eg. typing a "mount" command:
then, you would only have to type `mount ""`
and then just paste the full path
(that you have copied into clipboard from eg. Windows explorer)
Thank you!!
Reply 1 of 10, by gulikoza
This has already been discussed. It's impossible to make it crossplatform so the feature will most probably not be added.
http://www.si-gamer.net/gulikoza
Reply 2 of 10, by Fire&Ice
Sorry, do you mean that "copy/paste" is a unique characteristic of Microsoft Windows,
and that it doesn't exist in other operating systems ?
-You know, I'm completely unaware of OS other than Windows-.
And I was thinking that this suggestion I made, was really easy to incorporate.
PS. I've also tried to find a relevant thread in the forum,
but, since there isn't an option to "search message title only",
couldn't find anything.
Reply 3 of 10, by gulikoza
There is a wishlist thread here. I thought that copy/pasting was mentioned there but now I can't find it.
No, it's not a windows unique feature, but every OS does it differently. I believe that even linux has a few different ways of how to do it, so no it's not that easy to make it work everywhere.
Reply 5 of 10, by Fire&Ice
Well, thanks for your answers.
@gulikoza: so, would anyone mind if I posted my suggestion in the wish-list, too?
edit: I found this in the wish-list thread:
If a suggestion is already in this list or in therest of the thread then you do not need to chime in on how much you'd like this feature.
@collector: nice tip, thank you!! 😀
Reply 6 of 10, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Capturing a text mode screen to a text file would probably be the nearest cross-platform solution.
1+1=10
Reply 7 of 10, by coodan
In fact, there is a special tool to copy/paste in dos-mode for MS Win. 😎
http://copypaste.paqtool.com/
I tried it on WinXP - it does work. All you need to copy with it is mouse. 😀
Reply 9 of 10, by QuietGuy
DosFreak wrote:
huh? I copy and paste between NT4/2K/XP/2003 command prompt all the time without any special tools? Is this spam?
Seems like it: "Only 14.95$!" for something that doesn't do much special. Besides, it doesn't work on DOSBox. It's just a keylogger (just checked it out).
Reply 10 of 10, by QuietGuy
But when required, I can code a free tool for Windows which reacts on another shortcut then Ctrl+V and just does a sendkey for every char in the clipboard. I think that should work?
