Loading Saved Games
First post, by Sierrafan4life81
How do I get Dosbox to load my saved games? It doesn't seem to recognize the folder(s) that any of my saves are in...will this be worked on in a future version? Otherwise, awesome program!
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
it's probably a mistake on your side.
are you sure you mounted your drives correctly ?
Water flows down the stream
Reply 2 of 3, by Sierrafan4life81
I used the "drag and drop" method to run the games, I haven't used DOS in years, so I'm kinda "windows spoiled" :p If I do it the "techical way" will DOSBOX be able to read the drives correctly?
