First post, by p6889k
I got me MPU-401 ISA card and need help figuring out how to configure it together with AWE64 Value in Windows 98 and DOS 7 under Windows 98.
Right now my Autoexec.bat looks like this:
SET SOUND=C:\SB16
SET CTCM=C:\CTCM
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
SET MIDI=SYNTH:1 MAP:E MODE:0
C:\CTCM\CTCM.EXE
C:\SB16\AWEUTIL.COM /S
C:\SB16\MIXERSET.EXE /P /Q
I read that I should change SoundBlaster's Midi address from 330 to 300, since the MPU-401 card is set to 330. How do I do that? Can someone give me detailed instructions? Do I need to change something in Windows Device Manger? Do I need to manually change Autoexec.bat? What else? I need the MPU-401 to work when booting to DOS command line under Win98, and also to work for windowed DOS games launched from Win98.
Thank you,
Pavel
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
Dual PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
