Reply 60 of 63, by luckybob
- l33t++
hyoenmadan wrote on 2020-01-20, 23:25:luckybob wrote on 2020-01-20, 20:02:That said, if your system has PCI, you should use SATA and be done with it.
Again, stop with this "recomendation". SATA is a no go in older pre-Pentium3 platforms, except maybe if you are lucky to get one of these Promise SATA controllers with the first revisions of the chip (And even these will not work in PCI slots found in 486/Pentium 90 boards and less). Newer ones need features only present in PCI versions 2.2/3 and up (Pentium 4+ PCI chipsets).
Just because a board has PCI slots doesn't mean will be compatible with all PCI cards, specially for newer SATA and USB2 controller hardware.
With all due respect, pound sand.
All you said was "dont buy the cheap Chinese sata cards" which is a valid criticism, in ANY event.
