WORKING Shuttle HOT-613 (Single to Dual - Pentium Pro)
First post, by wiretap
So I am going to try converting a Shuttle HOT-613 (Single) into a Shuttle HOT-613 (Dual) by adding a CPU socket and VRM socket since it has the open spaces available on the motherboard. It appears I just need to remove the solder from the holes, then mount the two sockets. I have the connectors (new socket 8 CPU socket, and a VRM socket available I can desolder from a scrap board).
Does anyone have a good high-resolution picture available of the HOT-613 DUAL motherboard? Preferably I would like to see both CPU sockets unpopulated to confirm if I need to add or remove capacitors, and any surrounding areas that I may need to add components to. I know the 2nd CPU socket is missing some SMD capacitors, but those might be taken care of by adding the VRM module -- if not I'll need to see which ones I need to add, if it mirrors the first CPU socket or not. Capacitors on socket #1 that appear to be missing on socket #2 are labeled C226 (16V? / 22uF Tantalum).
Here are some pictures of my HOT-613 (Single) for comparison..
Whole motherboard with single Pentium Pro installed:
CPU socket #1 without the processor installed:
CPU socket #2 with the missing socket:
... the donor VRM socket(s) off a dual CPU Compaq server add-in CPU card:
Spare CPU sockets (new):
Two 5V Pentium Pro VRM units I have, one Compaq, one VXI:
My Github
Circuit Board Repair Manuals
Reply 1 of 74, by wiretap
Found a really low resolution image of the dual socket Shuttle HOT-613 and was able to identify where I need to add capacitors in the 2nd socket perimeter. Green - add 16V/22uF tantalum, Red - leave blank. Ordered the capacitors and I'll give it a go. As far as I can see, it isn't missing any other chips or passives, and the BIOS appears to be the same according to Shuttle's FTP.
My Github
Reply 2 of 74, by maxtherabbit
This is a badass project, godspeed!
Reply 3 of 74, by danijelm
Just for information you will need to get APIC ic.
the empty space for it is above the BIOS chip
For pentium 1 chip is Intel82039AA
I don't know if the P pro and P2 use same Apic
Find it on your donor Compaq server add-in CPU card.
Good Luck
I speak sarcasm as a 2nd language
Reply 4 of 74, by wiretap
Thanks for noticing that. I do have the chip on my Compaq CPU card, and I can transplant that as well. 😀
My Github
Reply 5 of 74, by wiretap
Looking at my Compaq server CPU board, it does not have the APIC. I was mistaken because the package size is the same, but it turned out to be a multi-i/o ethernet controller. But looking at other dual Pentium Pro boards on Ebay, they all have the Intel S82093AA. I went ahead and ordered one 'new old stock' since it was only $7 on Ebay from a US seller. (Seller: 1947transistor2012)
Hopefully that will do it and nothing else is missing. 😜 My SMD tantalum caps came in yesterday as well.
My Github
Reply 6 of 74, by wiretap
Solder removed from the VRM and CPU socket. That was fun to do with a manual hand pump.. haha. It really wasn't all that bad once I got a rhythm going. Very messy. Only took about 30 mins, but that was a lot of holes. Sometimes one suction would get 3 at once though, and it was very satisfying. 😜 If you need an epic solder sucker and don't want to buy a $125+ electrical one, get this one, because it is the only good one I've used: https://www.amazon.com/Engineer-SS-02-Solder- … r/dp/B002MJMXD4
Oh, and I just used a cheap hot air pencil and the solder sucker to do this. It made the work very easy/fast. Blow hot air on the solder you want to remove for a few seconds, suck it out, move onto the next.
My Github
Reply 7 of 74, by wiretap
With all the holes cleared of solder, here's a test fit of the new socket. Yup, that's gonna work. 😁
My Github
Reply 8 of 74, by chrismeyer6
Wow that is a serious labor of love. I can't wait to see how this project turns out.
Reply 9 of 74, by H3nrik V!
You'll be mounting the capacitors before soldering the socket, right?
Reply 11 of 74, by maxtherabbit
good gravy man, get yourself a ZD-915 and stop the masochism
Reply 12 of 74, by H3nrik V!
maxtherabbit wrote on 2020-01-29, 01:46:
One man's hobby is another man's masochism .. 🤣
Reply 13 of 74, by H3nrik V!
wiretap wrote on 2020-01-28, 22:16:
H3nrik V! wrote on 2020-01-28, 22:04:
Yes, although it isn't necessary and could be done after. I'll give myself some room though and do it before mounting the socket.
Yeah, I know that I would melt some ugly marks into that socket, if I'd mount capacitors after the socket 🤣
Reply 14 of 74, by wiretap
Caps mounted, APIC mounted, socket mounted, VRM socket mounted! Waiting on heatsinks for testing.. might be a few days.
My Github
Reply 15 of 74, by chrismeyer6
Seriously amazing job. Very excited to see the out come
Reply 16 of 74, by maxtherabbit
looks nice, clean job
can't you just slap some random heatsinks from something else on there just to see if it POSTs?
Reply 17 of 74, by wiretap
It posts and runs.. still only detecting 1 CPU. Maybe I need a different BIOS. Both CPU's are functional CPU's because I can run with either of them just in a single CPU configuration. With both installed, only 1 is detected by the BIOS, but both get hot so I know the 2nd socket is at least getting power.
My Github
Reply 18 of 74, by Garrett W
Amazing undertaking! I think you're right on the money on the different BIOS, should probably work if you find the appropriate one!
Reply 19 of 74, by Cyrix200+
Nice job!
1982 to 2001
