First post, by Gambit37
I'm trying to post a reply in the Glidos forum to this thread:
Dealing with the texture differences between the various versions of TR
However, when I try, I get a white page error:
Forbidden
You don't have permission to access /posting.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
It's odd that I can post in other forums OK. I'm using Firefox 1.0.4 -- I've cleared all cookies and cache and tried again but still getting the problem.
Any ideas?
Reply 1 of 5, by Gambit37
I tried posting different bits of my message and after getting success with some parts and not others, it turns out there is a problem with the text itself!
I'm not sure what the issue is. I obviously can't post the text in a message here as it won't work, but I've attached it as a TXT file -- if someone knows why this line won't post, I'd be intrigued to know!
Reply 2 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
Not sure. I resynced the forum and checked your account.
Water flows down the stream
Reply 3 of 5, by Snover
I hope you aren't using 1.0.4, there are lots of security vulnerabilities in that version. :E Anyway, the string "delete-from" is triggering mod_security.
Yes, it’s my fault.
Reply 4 of 5, by eL_PuSHeR
You should upgrade Firefox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 5, by Gambit37
Ah, that makes sense! Thanks for the update.
