Dosbox 0.65 on OS/2
First post, by josch
With the release of v0.65, I'm updating the OS/2 port.
But there seems to be a major screwup, since the keyboard mapping is reproducibly wrong.
It seems that the whole mapping is shifted some keys to the right and one row down.
Since the release notes talks about "improved keyboard [..] support", what was changed? (CVS doesn't work for me, the server always EOF).
Bye JoSch
Reply 1 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
the major difference is that the dosbox.conf variable usescancodes is set to true.
if you set it to false it might work better for you.
Water flows down the stream
Reply 3 of 21, by josch
Ok, I think that's it. I can imagine that there is a
#ifdef WIN32
#else // Linux
#endif
and so OS/2 falls through to the Linux implementation.
Ok. When I come home I will try this.
JoSch
PS: What's wrong with the repository? I cannot update or even login to the cvs server.
Reply 4 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
dunno.
I will file a bug report with sourceforge.
It's been out for over a week now.
Reply 5 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
hmm seems to be know issue.
anonon cvs isn't updated anymore until they have fixed things
http://sourceforge.net/docs/A04/
Reply 7 of 21, by josch
Since anonymous CVS is dead on SF.net, could someone of the core developers append the following to line 329 in sdlmapper:
&& !defined(OS2)
Thanks.
Reply 10 of 21, by wd
Rank DOSBox Author
DOSBox Author
Could you please have a look at MAPPER_StartUp (at the bottom
of sdl_mapper.cpp), i assume the defines there have to be
updated as well (either the linux/windows defaults already
work for os2, or a few modifications are necessary).
Those are for the cursor keys/num block pad, thus easy to test.
Reply 12 of 21, by josch
Ok, I had look at that code, and made it compile with the Win maps, but the whole right side of the keyboard doesn't work.
I have to make further investications for that.
Bye JoSch
Reply 14 of 21, by wd
Rank DOSBox Author
DOSBox Author
Have a look at static SDLKey sdlkey_map, this array has a translation
from a host-OS scancode (which sadly isn't a hardware scancode) to
SDL symkeys, so if we get scancode==1 it'll be translated into
sdlkey_map[1]==SDLK_ESCAPE.
Windows/Linux have almost the same scancode translation (linux has
an offset +8 which is removed in Bitu GetKeyCode()), and those keys
that have different scancodes require a change of sdlkey_map in
void MAPPER_StartUp(). Most likely this is enough for os2 as well.
To get a scancode for a key, search sdl_mapper.cpp for LOG_MSG("key type
and remove the comment before this line. Then hit those keys that don't
work yet, the last entry displayed by LOG_MSG is the scancode, then
you can add a custom translation in void MAPPER_StartUp().
Reply 19 of 21, by josch
Hi.
I just came around to packaging everything up.
I have attached my changes in sdlmapper.cpp to this post.
Please can anybody add it to CVS?
bye Jochen
    diff.txt
    1.56 KiB
    189 downloads
    Source code changes
