Blasterboard : A SB 2.0-compatible ISA sound card
Reply 400 of 567, by matze79
I`m fine with Blasterboard, no issues so far except windows compatibility .
almost all software works so far.
Reply 401 of 567, by root42
matze79 wrote on 2020-01-29, 22:37:
Ah, I only have the SnarkBarker setup for Windows. Never imagined there would be problems with the BB?
YouTube and Bonus
Reply 402 of 567, by appiah4
I hope to buy one soon, is there an updated batch to wait for?
Reply 403 of 567, by Jo22
canthearu wrote on 2020-01-29, 21:58:
I have my blasterboard assembled and working. It sounds great.
I was hoping LABS could make progress with getting it working with the windows SB 2.0 drivers, so it could permanently replace the SB 2.0 card in my 286.
I hope the same. Never really managed to get Windows 3.1 to use the SB 2.0 drivers - on a real SB 2.0!
Using the supplied Sound Blaster 1.5 drivers worked like a charm, though.
Even with SB Pro clones, emulated Sound Blasters and in Win 3.1 Standard Mode, too.
Reply 405 of 567, by canthearu
Jo22 wrote on 2020-01-30, 10:50:
I hope the same. Never really managed to get Windows 3.1 to use the SB 2.0 drivers - on a real SB 2.0! Using the supplied Sound […]
The SB2.0 drivers work fine for me in windows 3.1 standard mode on a 286 with an original SB2.0
Reply 406 of 567, by FreddyV
Hi LABs,
Difficult to do proposal if we don't have at least the decoding logic schematics.
If can probably be possible to do SBPro emulation by removing your filtering algorythm in Stereo mode. It will then have the same quality as the SBPro at minimum.
What I am waiting for are the support for SB16 Command (Signed DMA output) but you already know this.
Then, the use of CPLD is compatible with the "Do It yourself" spirit. Somebody wanting to spend time to build board can buy a cheap CPLD programmer and you can send them already programmed.
It will simplify the board a lot and add the possibility to do Tandy 1000, Covox, Disney, CMS with the possibility to decode more @
Reply 407 of 567, by LABS
I'll try to do my best to solve SB 2.0 drivers issue for w3.x, but I'm surprised that some of you guys have a separate card for that instead of using a better sounding BB with SB 1.5 driver, which works just fine. Any practical reason/titles? I already tried to solve it, but failed so far and switched to more important updates. However, if there is such a demand, I should disassemble the driver and look under the hood..
appiah4 wrote on 2020-01-30, 08:30:
Yes, new PCBs will arrive in about 10-12 days. They have a slightly different design now 😀
Sonic Buster 8: A NEW 8-bit ISA sound card with OPL3
Blasterboard: DIY SB2.0-compatible ISA sound card on ATmega MCU
Reply 408 of 567, by nathanieltolbert
Hello. I know I haven't been super active on this forum lately, but all of these new projects have been catching my eye. This is super impressive! I would love to purchase a DIY kit, but I appear to be missing the forms where I fill out that information and pay for the kit. I apologize if it's in bold somewhere. May I please get some help being pointed in the right direction? Thank you!
Reply 409 of 567, by LABS
FreddyV wrote on 2020-01-30, 13:15:
SB Pro + any further hardware modifications is a story for another project.
However, as it turned out recently, even in our calm and friendly retro village CPLD became a must just as a copy protection feature. But again, for another project.
Is your BB already in a stable condition? I have the testing code for you.
Reply 410 of 567, by LABS
nathanieltolbert wrote on 2020-01-30, 16:34:
Please check your PM.
Reply 411 of 567, by FreddyV
LABS wrote on 2020-01-30, 16:58:
I don't know. I did not test it yet.
I can send you a modified version of my player so that you can test.
Reply 412 of 567, by appiah4
LABS wrote on 2020-01-30, 16:31:
Sign me up for one please I will be getting my annual bonus soon 😁
Reply 413 of 567, by LABS
Sound comparison between Snark Barker (original SB replica) and BlasterBoard :
https://www.youtube.com/watch?v=ErTkQSvh_ls&feature=youtu.be
Thanks root42 for the video and Freddy V for native support of BlasterBoard in Mod Master player.
Reply 414 of 567, by Der Kuenringer
Happy to join this party. I'm sure it's going to be a blast(er)! hurhurhur
Reply 415 of 567, by Nitroraptor53
SAA1099?
Reply 416 of 567, by 640K!enough
I found an old article recently that mentioned problems with the Sound Blaster 2.0 drivers. The article claimed that the standard drivers tended to have problems on any system faster than a low-end 486. Creative released a "fixed" version, which the article claimed didn't work much better; they still had to disable the on-board cache just to get it to install properly. Their proposed solution on faster systems was to use the older drivers for the 1.5. Hopefully that can give some hint about what is going on.
Reply 417 of 567, by LABS
640K!enough wrote on 2020-02-17, 20:14:
Explains a lot, thx.
