First post, by bofh.fromhell
Anyone with a complete one that can help a fella out?
One component on mine has been knocked off somehow.
I'm assuming its a cap so values would be helpful!
Reply 2 of 6, by bofh.fromhell
i2lgames wrote on 2020-01-31, 11:40:
It looks to be a 16v 1000u capacitor
Curses 16v 1000u is my only weakness!
Tho on this ES it looks like a 16v 470u, wich means I'm in buisness again!
http://www.yjfy.com/images/oldhard/video/3D_P … 9000_PCI_ES.jpg
Thanks for the reply!
Reply 3 of 6, by bofh.fromhell
Well no dice.
Mobo post beeps but no monitor signal.
Card has been "repaired" by some previous owner tho so I guess its time to redo all that.
Or maby just bin it.
Dunno if its worth spending a lot of time on, even if it seems to be a somewhat rare card.
Reply 4 of 6, by i2lgames
That's odd, if there was a problem i don't think that it would post. Since it does then i think that it is a good thing. Does the motherboard boot from an internal video card? You can try all the outputs to see if you can get a picture.
Reply 5 of 6, by derSammler
I have many faulty video cards that just show a black screen but do not block the system from booting otherwise. That's not really odd.
Anyway, first check both VGA and DVI. Maybe it's only sending a signal to one of the two.
Reply 6 of 6, by bofh.fromhell
Slight update.
Reflowed what i could reach and cleaned the board thoroughly, previous owner left tons of flux.
And I now have a picture, well sort of:
Both analogue and digital looks the same =/
