First post, by LittleBubble
Hello,
Lately I put together a build with a Geforce MSI 4200 Ti in a motherboard which only has 4X AGP.
tkIwiSKWiJoJIRDTgWgvWkjboOLrLhrHtCmbD8cildHyqnH0ogSZcql7JcnfYMH4EPa8UsvTahG14Ippb-WUnfRGDiTFngj1xJZHrhPyOluKuMdXxVJT
As my research shows a lot of these AGP video cards did not take advantage of the 8X, it was marketing hype only. Same as with the AGP voodoo3 card which was the same as the PCI in speed, I would say only the AGP cards close to the pci express standard were taking advantage of the faster AGP bus, but a table would be nice of the cards which actually do use 8X AGP.
I don't have another board with 8X AGP at the moment so I wonder if someone experimented with this to see if there is really a performance gain on the 8X AGP compared to the 4X.
Comparing 2 different motherboards would be like comparing apples and oranges but comparison could be done with a board which has both 4X and 8X AGP on it.
The OS is Windows XP 32bt SP3 with DX9c (which is probably the best for this card).
I also wonder if changing this in the BIOS changes anything performance wise:
Graphics Aperture
SERR Signal Condition
ECC Config
32MB
64MB
128MB
256MB
512MB
1GB
None
None
Defines the size of system memory reserved
for AGP graphics data such as textures.
Usually, the higher the setting, the better
AGP performance, regardless of how much
actual RAM you have installed on your
motherboard.
Reply 1 of 8, by candle_86
Agp 8x only really showed improvement on much newer cards.
6800 ultra, x800xt or faster can utilize the bandwidth but ,4x doesn't cripple any of the agp cards until we get to say hd3850 and hd4650.
A ti 4200 will show the same performance in agp2x as it does 4x as it doesn't require the bandwidth.
Reply 2 of 8, by derSammler
LittleBubble wrote on 2020-02-05, 06:56:
Because bus speed and graphics card speed are two different things. It still makes a difference, as the faster the bus is, the shorter the load on it is to transfer a chunk of data.
Reply 4 of 8, by candle_86
derSammler wrote on 2020-02-05, 08:48:
Not quite, if the card can't make use of the bandwidth it's not going to. Anything pre 6800 or x800 has no chance of saturating the agp 4xbus, they simply are not powerful enough, they can't process that much data at once period. If the bus was a bottleneck you'd see an improvement as bus speed increases.
Reply 5 of 8, by Standard Def Steve
I've noticed that the CPU tests in 3DMark 2003 and 2005 really benefit from more bus bandwidth. Yet the actual graphics tests don't benefit much at all, at least once you're past PCI. Strange stuff.
Anyway on a PIII-S at 1628MHz with Apollo Pro 266T, DDR-310 @ 2-2-2-5, FSB at 155, AGP at 77.5, and PCI at 38.75.
3DMark03 CPU score:
GeForce 6800GT @ PCI: 160
GF 6800GT @ AGP 2X: 420
GF 6800GT @ AGP 4x: 536
3DMark03 Overall score:
GeForce 6800GT @ PCI: 6564 <-Wings of Fury took the largest hit, by far.
GF 6800GT @ AGP 2X: 9910
GF 6800GT @ AGP 4x: 10076
Reply 6 of 8, by swaaye
ATI's software Truform processing on non-R200 cards. Anything which "supports" Truform but isn't a Radeon 8500 or 9100. There is a huge increase in AGP traffic because the CPU is partially doing the geometry processing. You will see a substantial bus bottleneck at AGP 2x, some at 4x, but by 8x it will mostly be a CPU bottleneck.
Also, AGP readback performance improves with later AGP revisions and this is useful for things like Glide wrappers in some cases. It's still very slow compared to PCIe x16 however.
There's also the consideration that early AGP chipsets not from Intel tended to be problematic. So besides just improved specs, you have AGP and its various functions working better in general for VIA, ALI, NVidia, SIS, AMD. AGP4x chipsets were still often rather flakey but AGP8x boards tend to be solid. The main problems that occur with 8x are usually related to those cards with PCIe bridge chips AFAIK.
Reply 7 of 8, by melbar
@ Standard Def Steve
Thanks for your 3Dmark03 values. Interesting the difference between PCI and AGP2x/4x.
I have benched my 6600GT already. Later, i will try also 6800(GT)...
79.68 KiB
GPL-2.0-or-later
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 8 of 8, by The Serpent Rider
That's not real PCI though. More like PCI-X with exclusive and fast access to RAM. The real PCI bus would be even worse.
