Reply 80 of 314, by Bruninho
- Oldbie
So far I tested the releases from RoyTam1 on Windows 98SE (with KernelEx 4.5.2016.24) as of January 31, 2020:
K-Meleon 1.5.4 - Works but no CSS and no login on Vogons either. Almost nothing renders correctly. Forget YouTube.
K-Meleon 74 (Goanna 2.2) - The best of all I tried so far. Can render Vogons, I haven't tried to login yet, but fonts are messed up. The browser menubar icons are messed up. Does not play YouTube (Crashes, but I haven't installed a codec yet either)
RZBrowser and Retrozilla 2.2 (TLS 1.2) - Works, stable, renders Vogons without CSS, no YouTube, It can barely load any page without JS or CSS.
Pale Moon (for Win2000): I tried to load with compatibility set for Win XP SP2, but crashes on me even before the window. So no dice.
Retrozilla can log into Vogons, but needs to be tweaked as per comments above from other users here. And no CSS.
It seems to me that with a more polished work, K-Meleon 74 could be the best option for Windows 98SE actually. It needs more work.
JOBS, Steve.
