First post, by Intel486dx33
Is there Roland sound canvas with digital input 3.5mm ?
I want to be able to connect an AWE64 digital output to a Roland Sound Canvas ?
Or do I need to use the RCA outputs ?
Reply 1 of 2, by Spikey
RCA outputs. However, one model, the Roland SC-D70 has digital in and outs. It has no display, but does have a SC-55 compatibility map (50-75% the same, I guess?), and a SC-88, 88Pro, and 8820 map. It can be had relatively cheap, and also works as a sound card if you have USB support.
Reply 2 of 2, by daikatana_
SC-D70 has optical in and outs as well as RCA in and outs, there is no 3.5mm input.
It's pretty good actually. Unlike other Sound Canvases, Sc-D70 supports 48kHz. Using, for example SC-55 map in Doom, sounds exactly like the original soundtrack.
Game MIDI soundtracks
Retro games and HW reviews
