First post, by Jed118
- Oldbie
So I know that Ultima 7 is moderately difficult to get running on a PC, and it should run on a high end 386 or a low end 486 for best results. I have created boot disks and optimized the autoexec.bat and config.sys to maximize available memory, however, ultima7.com is started, it seems to load something, there's a slight pop in the soundcard, and then it exits to the prompt. The CPU I'm running it on is a 486 SLC at 50 MHz, 10 Mb RAM and an oddly configured 768k integrated video board. It is in an IBM Ambra computer, circa 1992.
Ultima does run (or at least start) on my PII 366MHz, but it is kind of unplayable due to the extreme speed boost. I used the same optimized boot disk on this machine.I have not tried it on my 386SX, but according to the sticker on the box, it requires at least a 386SX with 2 Mb RAM.
Here's what I've tried on my SLC:
-Disable cache
-Run the Ultima 7 patch
-Put in a 1Mb video card
-Boot from optimized hard disk (DR DOS)
-Boot from optimized floppy (MS DOS)
-Boot from optimized floppy (WIndows 98)
-Disable sound in the game setup (I'll try removing the soundcard, but I don't think it will make a difference)
Is there something obvious I missed, or does the SLC CPU have some weird quirk?
What's for sale? my eBay!
