First post, by wolf
I am trying to play all my games with the .conf having fullresolution=desktop, which makes everything clean, clear and amazing looking, but a massive chunk of the screen disappears on the screen's borders.
I tried changing the aspect on/off, different scalers and nothing. I even tried tried nVidia settings to let program and hardware scale handling just in case the culprit was my card.
Setting fullscreen=original just makes everything blurry.
So my question is am I missing something or a setting I didn't think about?
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
fullresolution=0x0
output=opengl
should be different from direct3d, as that is not a valid option.
But maybe take a screenshot, I might be misinterpreting what is missing.
of course if you are playing a non-16:9 on a 16:9 monitor then surely some parts are going to be black.
Water flows down the stream
Reply 6 of 11, by wolf
Well hells bells... I found the culprit! It was Windows scaling! Because my resolution is 4K, Windows defaulted me to 150% to help with text being to small.
I changed it to 100% to try and bingo! Fullscreen without the image going past the edge!!
Thank you for sitting with me and helping me through my questions!
Reply 7 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
Excellent, but this shouldn't happen with 0.74-3 I think. (the windows scaling causing a too large size to be picked, but maybe I made mistake in that code)
Are you using the latest version ?
Reply 9 of 11, by wolf
actually this maybe be harder for me to do. All my DOS games are using an SVN version but the windows (3.x/95) games are pre-made on https://collectionchamber.blogspot.com/
I can only asume he used the 0.74
Reply 11 of 11, by wolf
Ok updated to 74-3
And opengl 0x0 worked perfectly with my scaling sitting at the default 150%
I will just have to figure out how to apply this version into these older build for premade win games that is using an older DOSBox.
Again Thanks a million!!!
