AWE32 compatibility, like the iCD version of X-Com. Then get oplemu=compat to work. Then upgrade to OPL4 emulation, which is only found on the Yamaha SoundEdge, a Soundblaster Pro clone.
Could there be a wiki describing the install options of DOSBox - X? The initial decision between DirectX and OpenGL is big, I've tried it both ways and the OpenGL option is much simplified in terms of the size of the install.
Also, for DOSBox, I know it's simpler than DOSBox -X, but couldn't we get rid of the clumsy ctrl F10 method of releasing the mouse cursor?
Is there any way to report something like a Blaster status from the command prompt?
When version was oplmode added as a configuration option?
note: The directdraw install of DOSBox -X has been removed.
