dgVoodoo Splinter Cell Games
Reply 100 of 270, by AngryLittleAlchemist
I somehow ended up going down a rabbit hole of supposed fixes to the "bad image error"(or at least that's what I think it's called?). I got recommended messing with Windows 10 updates because apparently a lot of the forced ones ruin compatibility with certain software so I had to go and stop delete the updates and then stop Microsoft from automatically downloading them, didn't work. Somehow that led to a Bios update being a possible fix, which I was skeptical of, and while that was easy to do it took me 10 minutes to realize that the BIOS wouldn't recognize my keyboard because it was in the USB 3.0 slot instead of the USB 2.0 slot. That didn't work either.
I downloaded the microsoft debug tool from the debug layer thread and I don't think that did anything (although honestly I'm pretty sure I didn't use it correctly). If there's one thing I've learned from all this it's that I'm in no way a computer expert ...
edit: Sorry, I know that i'm not being very helpful, no one here probably knows the answer, just thought i'd log it to be sure, and also to vent 😀 🤣
edit 2: I just tried scanning the DLL file, scanning windows files. Spent a bunch of time making commands that would unregister and re-register dlls, none of it worked. 😠
Reply 101 of 270, by AngryLittleAlchemist
Oh my god! I got it to work!
All of these insane, complex fixes I attempted and I didn't even try the easiest fix of all ... downloading an older version of DgVoodoo! For me, the latest version of DgVoodoo does not work, but the last version, DgVoodoo 2.55.1 works! The funny thing is, I was at my wits end and the only reason I figured this out was by contacting some random user on a subreddit thread that was already months old. Haha!
Thanks for everyones help on this board - and hopefully if you have the same problem - installing the last version works!
Reply 102 of 270, by diagonally
Game: Splinter Cell: Pandora Tomorrow
dgVoodoo version: 2.55.4
dgVoodoo settings: https://pcgamingwiki.com/wiki/Tom_Clancy%27s_ … s_on_modern_PCs
Issue: The game (menus and actual gameplay) appears to be significantly dimmed. This is fixed by entering and exiting the options menu on the initial screen, at which point the proper brightness is restored.
Reply 103 of 270, by ed_barber
In the CIA HQ and Oil Refinery missions, there is bug appearing in dgVoodoo 2.61 where some textures appear to be black. See images below.
The attachment Untitled.jpg is no longer available
The attachment Untitled2.jpg is no longer available
The attachment Untitled3.jpg is no longer available
Reply 104 of 270, by Dege
Indeed, thanks. Fixed.
It was wrong with 2.6 too.
Reply 105 of 270, by lowenz
When you release the next WIP we are already ready to test it 😁
Reply 106 of 270, by hishamerrish
Hi guys ... i really love this game
so i tried something that gave some good results
I replaced the ( ETexRenderer.utx) from SC1 with the one from SCPT ... i got stronger light and smoother shadows like the xbox original ... here is Comparison photo
https://imgur.com/a/WtyLeA2
i tried to replace the ETexSFX.utx too ... it fix rain rendering in Kalinatek mission ... but corrupt it in other missons
i hope i could help you .... keep the great work ...
Reply 107 of 270, by hishamerrish
HI GUYS
i have strange bug ,...
The guards Bodies looks not right from far a way or through the sniper ... i do not know if any one has seen it before
thank you
here is a screen shoot
https://imgur.com/a/orhhp
Reply 108 of 270, by daniel_u
hishamerrish wrote on 2020-01-25, 01:31:
Hi guys ... i really love this game so i tried something that gave some good results I replaced the ( ETexRenderer.utx) from […]
Good find.I need to try this. 😀
Reply 109 of 270, by daniel_u
hishamerrish wrote on 2020-01-26, 01:45:
HI GUYS i have strange bug ,... The guards Bodies looks not right from far a way or through the sniper ... i do not know if any […]
HI GUYS
thank you
Yes, i know. But it's not the wrapper. Its the game engine. I tried some commands some time ago but nothing helped.
Without some dedicated dev/modder that really loves this game these will stay like this forever. 😀
Reply 110 of 270, by hishamerrish
daniel_u wrote on 2020-01-27, 07:49:
HI GUYS
thank you
hi
i found its happening when i use 4k or AA with the game ... dose not happen with the 2k or 3k .... i tried many thing but no luck 🙁 ... i wish modders do some thing to fix this game 😀
Reply 111 of 270, by Greenberet
Weird night vision bug from versions 62x and up
Hello yesterday downloaded splinter cell to replay this classic on steam and encountered some weird night vision bug using dgvoodoo2 62x and up
So my pc specs very old pc:
Athlon x2 5000+
2gb ddr2 800
geforce 8600 gt 512 mb
windows 10 32bits latest updates.
dgvoodoo2 config(using same settings on all versions)
The attachment Untitled2.png is no longer available
The attachment Untitled1.png is no longer available
The attachment Untitled.png is no longer available
the bug:
does not happen with version 55_4_1 only with 62x and up
Working as intended? with 55.4.1(exact same as vanilla):
https://www.youtube.com/watch?v=9-MmUNoLqOI
The night vision flicker bug with 62x and up:
https://www.youtube.com/watch?v=M1rmKkKsPkU
Reply 112 of 270, by Dege
It's strange. I gave it a quick shot with the current dev version, at the same location but it worked as expected.
Does it flickers for you everywhere in the game?
Reply 113 of 270, by Greenberet
Dege wrote on 2020-02-29, 12:34:
yes its only the night vision tho as you saw in the video everything else is perfect,and only if i use dgvoodoo2 62* and up, with version 55* that does not happen(first video)
its no biggie i am just using version 55
Edit: maybe something to do with "feature level 10" on the output api? since i have to do that because 8600gt only supports directx 10
Reply 114 of 270, by extreme55555
what nvidia driver you're using Greenberet ? try using 314.22 driver
Reply 115 of 270, by Greenberet
extreme55555 wrote on 2020-02-29, 22:54:
341.74 its the one windows 10 auto downloads and install
there is newer one for the 8600gt but i am too lazy right now to uninstall->safe mode,use DDU then boot normally and install the newer one =P
314.22 i don't think is compatible with win 10 32bits
But its no biggie like a i said i am just using the 55 version conf.
Just letting know in case someone with the same issue =D
Reply 116 of 270, by Arko86
@Lowenz and @Daniel_u
I got good news guys. Some months ago, when dgvoodoo was only predx9 games only, I asked dege if he could fix transparent ice in DA.
Seems like it's fixed now:
"Find and replace these bytes in D3DDrv.dll:
8A 86 5D 5D 00 00 83 C4 10 → 30 C0 90 90 90 90 83 C4 10
Set FSAADegree=2 in SplinterCell4.ini"
Thanks to killer-m from Github.
Reply 117 of 270, by lowenz
Thanks!
Reply 118 of 270, by daniel_u
Arko86 wrote on 2020-11-10, 13:20:
@Lowenz and @Daniel_u […]
Great news !
Does this guy have the time to look into other Splinter Cell related issues? There are a couple i described in my posts.
Looked in git, not sure i see this user doing patches for games. 😀 Do you have a link with his git page.?
Reply 119 of 270, by antrad
daniel_u wrote on 2020-11-16, 21:13:
Great news !
I bookmarked this page where he posted some SC stuff. I think killer-m is jackfuste that was active on WidescreengGaming forums until it shut down. If that is really him, he is a very friendly person, helped me few times when I asked.
https://github.com/ThirteenAG/WidescreenFixesPack/issues/725
https://antonior-software.blogspot.com
