Reply 360 of 456, by 8088mph
Got mine today. Waiting on PC speaker cables but the audio out jack works.
Which VGM files are compatible with the card? Is there a collection somewhere?
I'm new here. How do I PM?
8088mph wrote on 2020-02-14, 18:17:Got mine today. Waiting on PC speaker cables but the audio out jack works.
very good!
usually you can also use a CD-Rom Audio Cable for Connection.
as i only play games with the card (mostly) i have not packaged up a collection i just have 3 vgm files.
But there are many vgm download sites on the net, i don`t even know if they are legal.
its also possible to convert midi files to vgm.
https://vgmrips.net/forum/viewtopic.php?t=1929
At least there are 2 Players,
sbvgm and vgmplay
@NitroRaptor
you can`t PM until you have some posts.. i don`t know the exakt amount right now.
Hello there. I'm new to the forum and very interested also 😀
@matze79 if per any chance you still have some left, can you please send me a PM?
Thank you!
all cards and kits found owners 😀 as promised everyone will get a chance to gain a card soon.
There will be a official way to obtain one!
OK, thanks for the quick reply.
Looking forward to get my own 😀
https://www.youtube.com/watch?v=KJ6PgTIf00o
root42 will do Live Soldering of tndy card
EDIT: Date changed:
28. Februar, 20:30 - Central European Time
Enjoy the Show!
root42 wrote on 2020-02-28, 19:28:Live Stream starting in 2 minutes 😉
Watching !
Thanks for your support !
And one sample of the new card, Populous:
Apart from me being confused by the labelling of the components, it turned out really well! Thanks, matze!
What device do you use for recording ?
@fagear what vgm files did you test ?
Sonic Title ?
matze79 wrote on 2020-03-02, 12:12:What device do you use for recording ?
Were you referring to me? In these new videos I use a 3 channel Behringer USB mixer to capture the audio. Before I was using the OSSC with a USB3 HDMI capture card.
I added a few more videos to my second channel using the new card:
https://youtu.be/l3cyuRbzKCM
https://youtu.be/R_TJoeK3EqQ
https://youtu.be/Okonh3xdAFc
this sounds like PC-Speaker only.
You need to PATCH Prince.exe for Tandy Sound.
EDIT:
Ah ok its POP2.. but it should also work. I had 3 Voice Sound with this Game.
matze79 wrote on 2020-03-02, 18:23:https://youtu.be/l3cyuRbzKCM […]
EDIT:
Hm. I used PoP 1.3 with Tandy as music. Same for PoP2. But I also thought it sounded like PC speaker. I will try again!
Yeah for Prince of Persia 1 you need to hexedit the EXE File..
Just unpack the EXE and Hexedit.
http://nerdlypleasures.blogspot.com/2015/08/p … sound-card.html
Jan Knipperts bumped Version of Test Tandy Software
TEST TANDY v0.51
New Features
Version 0.51:
- MDA, Hercules Graphics
- Testsequenz / Test Sound
- Command Parameter
Testing Sequenze with -> /TEST <Port> -> TESTTNDY.EXE /TEST 1E0
Or Keypress F1
/K -> Keyboard Control (No Mouse)
/MDA -> Force Monochrome Mode
/COLOR -> Force Color Mode
/? -> Help
Maybe some day this will become a TANDY Tracker 😳
matze79 wrote on 2020-03-02, 21:43:Yeah for Prince of Persia 1 you need to hexedit the EXE File..
Just unpack the EXE and Hexedit.http://nerdlypleasures.blogspot.com/2015/08/p … sound-card.html
That concerns PoP 1.0. I was using version 1.3 which comes with a setup program to pick the sound card. I will investigate what Settings work... maybe they check for Tandy Bios and revert to PC speaker?
Yes, i`m pretty sure it will do tandy checking.
matze79 wrote on 2020-03-03, 15:34:Yes, i`m pretty sure it will do tandy checking.
Ok, then I will try again with PoP 1.0 and patch the binary.
I edited PRINCE.EXE from the 1.0 release, and at the given position changed the 75h to EBh. But no luck. I get Adlib only sound. Any ideas?
EDIT: "prince vga tandy" leads to sound, but it seems monophonic. could the PC beeper (which is attached to the TNDY card). "prince vga gblast" hangs the system, with the SnarkBarker (including SAA1099) installed.
