First post, by balthazor4ever
I hope I write in the right section. I bought this controller from ebay. I read somewhere that in order to have better speeds you need a driver to enable the features of the controller. The thing is by searching I found datasheets of the chips on the controller but I haven't found any driver for DOS or Windows 3.11. Can anyone help me?
Reply 1 of 12, by digistorm
Is it this card?
The attachment IMG_0079.jpg is no longer available
I have a driver disk for this card that came with my 486. I could send you a disk image, or I could upload it to this forum if that's possible.
Reply 3 of 12, by balthazor4ever
digistorm wrote on 2020-03-07, 16:00:
Is it this card?
I would appreciate that. How could we do this?
Reply 4 of 12, by Horun
balthazor4ever wrote on 2020-03-07, 21:00:
Is it this card?
digistorm: If it is less than 2Mb (zipped) you can attach it to a reply here in this thread.
Reply 5 of 12, by digistorm
I put them in a zip file, then they don't take up that much space. There is also a paper manual with it, I don't have a scan at the moment, but if you need it I can scan it tomorrow.
Reply 6 of 12, by Horun
digistorm wrote on 2020-03-07, 22:29:
Great ! Thank you. Am saving it to my driver library 😁
Reply 7 of 12, by Robin4
Me too, there is always a backup from my side. Thanks for sharing. I put all the collected files on my NAS. Because google is drying up on information and drivers.
Reply 8 of 12, by balthazor4ever
Thank you so much!!!!
Reply 9 of 12, by balthazor4ever
I don't have any manual. If you find the time to scan it I would be most thankful!
Reply 10 of 12, by digistorm
Here is the manual. It's a folded piece of paper, so the scan may look a bit weird, but I think you'll figure it out 😊
Reply 11 of 12, by balthazor4ever
Great! Thank you very much!
Reply 12 of 12, by douglar
Unfortunately, I can't get that driver to work with a card that uses the "6560A" chip. Says the card is not a "6560B". Anyone have a driver for the 6560A?
Frustratingly, I see drivers here: https://storagedrivers.com/companies//461.htm
That sight list of the contents of potentially newer driver disks for "6560A" and "6560B", but the downloads only take me to outbyte-driver-updater.exe, which doesn't seem safe.
