Reply 42 of 49, by Mau1wurf1977
Yea not sure what's going on there. That page simply doesn't come up in my google results. Maybe it is because I live in Australia?
Anyway thanks for the link 😀 I don't think I will be using this game though.
My YouTube channel
Reply 43 of 49, by Stiletto
Or maybe you don't normally search for video games, so your "search bubble" excludes results? It's getting complicated these days.
With this query, vetz's link is the 25th result. Perhaps you should change your Google result settings to paginate on every 100 results (like I do), rather than on every 10. There are probably ways to further tune the query to make it appear higher.
https://www.google.com/search?num=100&safe=of … +%22Falcon+4%22
https://www.google.com.au/search?num=100&safe … +%22Falcon+4%22 (identical)
[EDIT] With judicious use of quotation marks, we can get vetz's page to the top 2.
Hope this helps you search in the future. 😀
do the Fandango!" - Queen
Stiletto
Reply 44 of 49, by F2bnp
meljor wrote:
Does drakan have a build-in benchmark?
Yep. You have to use some switches on the shortcut. Can't remember which ones though!
Reply 45 of 49, by AlphaWing
Viper Racing has a benchmark with a time demo built in it.
Its a DX5\Dx6 Game About racing dodge vipers 🤣.
I think It had Glide support too... its been awhile since I played it I have the CD here so I think I'll try it again and see if it does.
No glide just tried it. Celeron333+V3 got 52fps on max settings @ 800x600 with its benchmark 🤣 .
Reply 46 of 49, by archsan
Does anyone remember Redline Racer? I think it was used in an early Tom's (or was it PC World) 3d accelerators roundup and I remember it having fps counter but not sure about it having "timedemo"-like feature that you can activate with a command line.
Also maybe you'll find something interesting in this page: http://home.scarlet.be/voodooclan/benchmarks.htm
"Any sufficiently advanced technology is indistinguishable from magic."—Arthur C. Clarke
"No way. Installing the drivers on these things always gives me a headache."—Guybrush Threepwood (on cutting-edge voodoo technology)
Reply 47 of 49, by meljor
Occasionaly i play redline racer but i don`t know anything about a fps counter, could be interesting....
Reply 48 of 49, by Takedasun
Timedemos for Shogo.
Reply 49 of 49, by SerialThriller
Takedasun wrote on 2020-03-11, 15:32:
These are just what i'm looking for!
But how did you create those demos? I've been trying to get demo recording to work in Shogo for so long. The console command is meant to be something like this:
record <map_name> <demo_name>
But that doesn't work. The game says that it can't load the map even though the map name is correct... (sorry to necro this old thread btw)
