7800 or 7900 series?
First post, by pentiumspeed
Does this matter if older games works best on 7800 and what about 7900?
Just curious, I'm planning to use one for XP to use older games that still works in DOS mode and that still works in XP instead of 98se?
Oh yeah, I'm still planning to build a 98se computer box for some games that will not work in XP.
Thanks and cheers,
Great Northern aka Canada.
Reply 1 of 46, by agent_x007
Try sticking to 256MB VRAM of 7800 GTX/7900 GT.
With 512MB VRAM there are issues NV driver has (you need a fix to make it work properly under Win98).
Reply 2 of 46, by lost77
If you are running XP there is no difference between the two. They use the same GPU architecture.
Reply 3 of 46, by pentiumspeed
Perfect, thank you. I knew 98se is odd in a way but this is out of the scope of this 7x00 video cards. I have hard ware set aside for 98se already but was not sure about 7800/7900 to use for XP.
Cheers,
Reply 4 of 46, by candle_86
For XP just grab a 7900GTX they cost the same as a 7800 or lower end 7900 these days. Better yet grab an x1900 card for similar prices but faster in everything that uses shaders and opengl was fixed by now.
Reply 5 of 46, by pentiumspeed
What about x1950 series?
PS: I purchased:
Two Quadro FX 4500 with rigid SLI bridge as a kit for good price. This is version of GTX 7800 512MB
One Quadro FX 5500, which is like GTX 7900 except this is 1GB rather than 512MB. FX 5500 is much easier to find than 7900 GTX which is for strange reason rare. 7900 GTO is easier which I also purchased as well.
I already have 7900 GTX in storage which I purchased nearly 2 years ago when it was bit more plentiful there.
Also found and purchased kit flexible version of cross fire and SLI bridges. Hard bridges is much harder to find for 1 way SLI in any length, Needs one 40mm and one 60mm rigid SLI bridge, no need for HB type.
Cheers,
Reply 6 of 46, by candle_86
The 1950 is also great. The 1950 xtx is the fastest single gpu dx9 card to ever be built.
Reply 7 of 46, by The Serpent Rider
Not nessesarily. Most likely they will be packed with G71 chips. So it's more like 7900GT with better PCB.
Horrible choice for gaming. These cards use GDDR2 with anemic 1 Ghz clock. You'll be lucky to overclock it to standard 7800GTX memory clock (1200 Mhz).
Reply 8 of 46, by pentiumspeed
Both are Quadro cards I know these, and both are 256bit, GDDR3, clocked same as well (1050MHz) and is less bandwidth too for being Quadro. Same reference PCB boards like the GTX 7900 I have in storage.
G70 for Quadro FX 4500, G71 for Quadro FX 5500. Both fully enabled chips like GTX/GTO/7900 GT are. 7950 GT is not same category as it has also fully enabled chip plus 4 more features that other G70/G71 don't have.
Cross checked from wiki list of nvidia GPUs and techpowerup.
Cheers,
Reply 9 of 46, by The Serpent Rider
7950GT is G71. It has identical features.
Reply 10 of 46, by pentiumspeed
I don't know why you got the DDR2 reference and I did find the AIDA64 incorrectly reports memory type as DDR2 for Quadro FX5500 which I received today and tested it.
Try GPU-Z.
BTW, GDDR2 chips is usually used on low end video cards and is totally different from bit larger GDDR3 chips.
Cheers,
Reply 11 of 46, by greasemonkey90s
The only gtx 7800 worth a damn is the 512mb version which is rare. Freaking beast . but yea 7900 gtx if all else fails.
Reply 12 of 46, by pentiumspeed
I know that. This is reason I'm exploring alternatives of Geforce 7800/7900 cards.
Cheers,
Reply 13 of 46, by greasemonkey90s
pentiumspeed wrote on 2020-03-14, 02:29:
Cheers,
Like others have said best alternative x1950 pro or xt
Reply 14 of 46, by swaaye
X1000 series certainly will get you nicer image quality. Better anti-aliasing and texture filtering and that floating point blending ability for HDR+AA in Oblivion (super important 🤣)
GF7 will have better overall game compatibility however.
Reply 15 of 46, by RacoonRider
swaaye wrote on 2020-03-15, 21:19:
😁 Back in the day I convinced my family to buy me a new PC because of Oblivion. E6300 and x1800GTO were not really enough for it, and only Q6700 and HD4870X2 made the game really playable for me 8 years later 😁
Reply 16 of 46, by Methanoid
pentiumspeed wrote on 2020-03-08, 19:33:
What about x1950 series? […]
PS: I purchased:
Cheers,
Does Quadro FX5500 work in W98? Does it need any patches or special drivers?
Reply 17 of 46, by The Serpent Rider
FX5500 has 1 Gb of VRAM. It won't work with stock Win9x.
Reply 18 of 46, by DarthSun
The 7900 advantage is that it is suitable for a Win98/XP secondary card within one a machine, even in beast Zen2.
Quadro FX3500 (7900gs)+R3800x.
https://cdn.rios.hu/dl/upc/2023-12/02/225621_ … g_70665_w98.jpg
https://cdn.rios.hu/dl/upc/2023-12/02/225621_ … ovecx_71855.jpg
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 19 of 46, by The Serpent Rider
For Win9x, Radeon X800/X850 are better though, because GeForce 6xxx/7xxx series are quite broken in many ways.
