First post, by Lylat1an
While they work, those two files have become a mess on my machine and I want to reorganize them.
I'm seeing guides online that tell me what the different functions do, but not how they should be arranged.
Also, is it REM or a semicolon that tells DOS to ignore lines in these files?
Thank you.
Reply 1 of 6, by jesolo
As a rule of thumb, always load those device drivers that take up the most memory first and work your way down.
Depending on what version of DOS you're using, type mem/c |more to see what is taking up the most memory.
Loading DOS into the Upper Memory Area also frees up some conventional memory. Use the DOS=HIGH parameter in your Config.sys file.
The REM command is what tells DOS that the line is a "REMark".
DOS 6.x has a very nice Help system that also provides more info on the various commands.
Reply 2 of 6, by cyclone3d
Don't forget about manually setting up the include memory range(s) for UMBs. You can gain a decent amount of UMBs by doing this. Be prepared for some trial/error and lockups along the way in order to get it all set up though.
If set up properly, you should be able to realize close to or above 600KB free conventional memory.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 6, by root42
Actually DOS=HIGH,UMB is the way to go for all systems that support it. UMB will need EMM386 to run, or a dedicated UMB driver for 286 systems.
DEVICEHIGH all drivers as far as possible, LH all TSRs. Reduce STACKS and FILES to reasonable values (not too low so nothing runs). Getting more than 600KiB of memory should be no problem.
YouTube and Bonus
Reply 5 of 6, by dr_st
This is what I did.
You can just copy and paste the contents of your files here and receive some suggestions for optimizing them.
Reply 6 of 6, by Stiletto
Moved to Marvin -> Software.
do the Fandango!" - Queen
Stiletto
