First post, by Paar
I have this Creative TNT2 Ultra card that works fine but outputs yellow picture. The problem is that there is interrupted path to the VGA connector, component L8 (see picture). I don't have any experience with these types of components. Do you have any idea what it is and how can I know what value it has to have to properly replace it?
Reply 1 of 5, by aaronkatrini
If I'm not mistaken usually on the PCB components are named:
R - Resistor
C - Capacitor
L - Inductor
So the L8 should be an inductor, however the value is difficult to determine without a schematic of the card. Best bet would be desolder the L12 and L13, measure them, and if they're identical, I'd assume that L8 has the same value, since the traces "run in parallel".
I'm no expert by any means, so hopefully someone can help better.
Reply 2 of 5, by Tiido
Short out those inductors and you get a sharper image (and remove the little capacitors sitting between video signal and ground).
Reply 3 of 5, by Paar
aaronkatrini wrote on 2020-03-17, 08:42:
That's the thing - is it possible to measure them with only a multimeter?
Tiido wrote on 2020-03-17, 12:24:
You mean remove the inductors and connect the trace directly?
Reply 4 of 5, by Tiido
Yes, remove inductor and connect the two pads together (or put a wire across the inductor, but that won't look as neat usually). Those inductors and capacitors form a peaking network that relies on resonances to boost transitions of signals that makes some resolution (say 1024x768) look little sharper while all else gets a bit blurrier or even worse gets trailing on right side of details. Whenever I remove them I get significantly sharper image.
Reply 5 of 5, by Paar
I'll try that, thanks for the tip.
